Digital filter response question
The digital filter defined by the equation yn = xn - n-2 - 0.81*yn-2 has a frequency response characterized by H(z) = [z² - 1] / [z² + 0.81]. The filter response is zero at frequencies 0 and fN, where fN represents the Nyquist frequency. To find the frequency that maximizes the filter response, one can utilize calculus to analyze the magnitude of F(ω) = [e²jωt - 1] / [e²jωt + 0.81]. The maximum response occurs when the numerator's magnitude is at its peak while the denominator's magnitude is at its lowest.
  • Understanding of digital filter design and response analysis
  • Familiarity with complex numbers and their representation in the complex plane
  • Knowledge of calculus, specifically techniques for finding maxima and minima
  • Basic concepts of Nyquist frequency and its significance in signal processing
  • Study the properties of digital filters, focusing on frequency response and stability
  • Learn about the Nyquist theorem and its implications for sampling rates
  • Explore techniques for maximizing functions in calculus, particularly in the context of complex functions
  • Investigate vector representation of complex numbers and their applications in signal processing
Students and professionals in electrical engineering, signal processing, and applied mathematics who are working with digital filters and frequency response analysis.
jmher0403
A digital filter is defined by yn = xn - n-2 - 0.81*yn-2.
At what frequency, in terms of fNyquist, is the filter response zero and maximum?
H(z) = Y(z)/X(z)
I figured out that H(z) = [z2-1] /[z2 +0.81]
and F(w) = [e2jwt -1 ] / [e2jwt + 0.81]
= [cos(2wt) + isin(2wt) - 1] / [cos(2wt) + isin(2wt) + 0.81]
Please give me some advice on how to go on about finding the frequencies please...
Hint was given that wt = ∏ f/fNyquist
please also explain why this is so...
Thanks a lot in advance :D
I figured out the frequencies that give zero are 0 and fN
any hints on how to find the frequency that gives maximum response?/?
You could use a bit of calculus to find minima/maxima of |F(ω)|, you've probably done this plenty of times before with real-valued functions.
F(ω) has a simple property, though, that, by inspection, enables you to find the value of ω that maximizes |F(ω)|. When the magnitude of the numerator attains its maximum value, the magnitude of the denominator attains its minimum value. That means something for the magnitude of the fraction.
I don't know how familiar you are with complex numbers and their interpretation as vectors in the complex plane, but if this means something to you, you might interpret the numerator as the vector sum of 1∠2ωT and 1∠180°, where T is the sampling time of your system (one might confuse an expression with t as a time-domain expression).
  • · Replies 26 ·
