S2 - S1 > Integral 1-2 dQ/T Irreversible Process. What T ?
The discussion revolves around the evaluation of entropy change (S2 - S1) in an irreversible process, particularly focusing on the integral ∫12 dQ/T and the appropriate temperature values to use in this context. Participants explore the implications of heat transfer between two objects at different temperatures and the limitations of applying certain formulas in irreversible thermodynamic processes.
  • Some participants assert that for an irreversible process, S2 - S1 > ∫12 dQ/T, but question what temperatures should be used in the integral.
  • Others argue that the temperature is variable during the heat transfer and that using only the extreme temperatures is insufficient without an equation for heat transfer.
  • One participant notes that the formula has a restricted range of applicability since temperature may not be well-defined during a general irreversible process.
  • Some participants emphasize that to calculate the change in entropy accurately, one must use a reversible path, suggesting that the original integral is derived from ΔS = ∫dQrev/T.
  • Another participant provides a specific formula for quantifying entropy change in heat transfer between hotter and cooler objects, indicating that the evaluation is qualitative in nature.
Participants express disagreement regarding the application of the integral ∫12 dQ/T in irreversible processes, with some asserting its limitations and others proposing alternative approaches. There is no consensus on the correct method for evaluating the entropy change in this context.
Limitations include the dependence on the definitions of temperature during irreversible processes and the need for a reversible path to accurately calculate entropy changes. The discussion highlights the complexity of applying thermodynamic principles in non-equilibrium situations.
Point Conception
For an irreversible process: S2 - S1 > ∫12 dQ/T
In the case of heat transfer dQ between object with T1 to object with T2, T1 > T2
ΔS in Joules/K is known But for evaluating ∫12 dQ/T = ln dQ/T - ln dQ/T . d/Q is known but what values for T in this case ?
Object 1 & 2 have Temperatures before heat transfer and different temperature after
Science news on Phys.org
The temperature is variable along the integration, while heat change. Only with the 2 temperatures extremis is not possible use these formula to solve any problem. You need an equation for heat transfer, for example. This is really no thermostatics, it requires thermodynamics, from empirical equations or from statistical mechanics treatments
morrobay, you are right that this formula has quite a restricted range of applicability as T may not be defined during a general irreversible process.
Thanks, would you please check my numerical problem on this in the Homework section;
Introductory Physics. Topic : Entropy for Irreversible Process.
This is incorrect if by dQ you mean the actual heat flow in the process. To calculate the change in entropy, you have to use a reversible path between the beginning and end states
[tex]\Delta S = \int_{rev path} \frac{dQ_{rev}}{T}[/tex]
AM
AM
Yes it seems that S2-S1 > ∫12dQ/T
is just qualitative. As Chestermiller showed one way to quantify S2-S1
in heat transfer between hotter and cooler object is with.:
Δ S = mCv(ln T2/T1+lnT2/T1)
Where the first ln T2/T1 is for hotter object losing heat and second
ln T2/T1 for cooler object gaining heat.
What is the original integral that this evaluation was derived from ?
It is derived from ΔS = ∫dQrev/T:
For the hotter object (body A), a reversible path from T1 to T2 would be found by placing it in thermal contact with a body that has an infinitessimally lower temperature and whose temperature keeps decreasing so as to maintain that infinitessimal lower temperature as heat flows out of A, until it reaches T2. For that path:
[tex]\Delta S_A = \int_{T_1}^{T_2}\frac{dQ}{T}= \int_{T_1}^{T_2}\frac{mCdT}{T} = mC\ln T_2 - mC\ln T_1 = mC\ln\left(\frac{T_2}{T_1}\right)[/tex]
Similarly the change in entropy of the cooler body, B is:
[tex]\Delta S_B = mC\ln\left(\frac{T_f}{T_i}\right)[/tex] where i and f denote initial and final temperatures of Body B.
AM
  • · Replies 29 ·
  • · Replies 30 ·
  • · Replies 22 ·
