How Do You Calculate the Speed and Retarding Force in a Momentum Problem?
The problem involves a boy jumping onto a stationary canoe, requiring the calculation of their combined speed after the jump and the average retarding force acting on the canoe as it comes to rest. The subject area includes concepts of momentum and forces in motion.
  • Participants discuss the application of momentum conservation to find the speed after the boy lands on the canoe. There is uncertainty regarding the calculation of the retarding force, with some suggesting the use of kinematic equations to find deceleration.
Some participants have confirmed the initial speed calculation, while others have raised questions about the correct approach to finding the retarding force, indicating a need to clarify the system being analyzed (canoe only versus canoe plus boy).
There is mention of the need to consider the mass of the canoe separately when calculating the average retarding force, highlighting potential assumptions about the system's dynamics.
TheRedDevil18
A boy of mass 60kg, running at 5m/s jumps on a stationary 15kg canoe and they move of together.
1.1) Find their speed just after the boy lands on the canoe
1.2) If the canoe comes to rest after moving through a distance of 15m, calculate the average magnitude of the retarding force on the canoe due to the water
momentum before= momentum after
Impulse = Change in momentum
Unsure about 1.2
1.1) 4m/s(momentum before = momentum after)
1.2) t=d/s = 15/4 = 3.75's
f*t = m*v
3.75f = 75(combined mass)*4
F = 80N
Could someone check
Hello TheRedDevil18,
Unsure about 1.2
Correct !
f*t = m*v
F = 80N
Could someone check
Hmmm. Wrong. Constant resistive force is acting on the canoe system. You will have to use third equation of motion, v2=u2-2ad... Find deceleration a...
Correct !
v^2 = u^2+2ad
16+30a = 0
a = -0.53m/s^-2
Fnet = ma
= 75*-0.53
= -39.75N
Would this be correct?
TheRedDevil18 said:
v^2 = u^2+2ad
16+30a = 0
a = -0.53m/s^-2
Fnet = ma
= 75*-0.53
= -39.75N
It is asking for the average retarding force exerted on the canoe system, and not the "canoe+boy" system.
You need to consider the mass of canoe only.
18K
  • · Replies 18 ·
  • · Replies 31 ·
  • · Replies 17 ·
  • · Replies 25 ·
12K
