Fortran Problem in Extracting Numercial Values in fortran
  • Thread starter Thread starter equillibrium
    Fortran
The discussion revolves around an issue with reading numerical values from a text file using Fortran with an IBM compiler. The user is experiencing a problem where the program skips the loop between the 'Beta' section and the 'END' marker, leading to errors in reading the data. The input file contains both text and numerical data, and the user has tried using a 'do while' loop but encounters read statement errors due to unexpected characters in the input. A suggested solution involves reading the entire file as text first to count the data entries, then rereading the file while skipping non-numeric lines. The user successfully implemented this approach, resulting in a functional program. Additionally, there was a recommendation to avoid using 'goto' statements for cleaner code structure.
equillibrium
Hello all,I have a small doubt. I use F95/90 and IBM compiler.This is a portion of my text file
Alpha Singles Amplitudes
15 3 23 4 -0.186952
15 3 26 4 0.599918
15 3 31 4 0.105048
15 3 23 4 0.186952
Beta Singles Amplitudes
15 3 23 4 0.186952
15 3 26 4 -0.599918
15 3 31 4 -0.105048
15 3 23 4 -0.186952
END
I am trying to extract the numerical values from the attached file 1.txt . and I am facing a strange error in the output which I cannot understand. Every time I execute the program it skips the loop between 'Beta' and 'END'. I am trying to read and store the values.
The number of lines inside the Alpha- and beta loop is not fixed. So a simple 'do loop' is of no use to me. I tried the 'do while' but it gives the output as :
AS 15 3 23 4 -.186952
AS 15 3 26 4 .599918
AS 15 3 31 4 .105048
AS 15 3 23 4 .186952
1525-097 A READ statement using decimal base input found the invalid digit 'a' in the input file. The program will recover by assuming a zero in its place.
1525-097 A READ statement using decimal base input found the invalid digit 'e' in the input file. The program will recover by assuming a zero in its place.
1525-097 A READ statement using decimal base input found the invalid digit 'p' in the input file. The program will recover by assuming a zero in its place.
1525-097 A READ statement using decimal base input found the invalid digit 'l' in the input file. The program will recover by assuming a zero in its place.
This is the end
Any suggestions would of of great help. I coudn't find the error in logic in my code.I have attached the code (Text.txt).
Thanks in advance
Technology news on Phys.org
At one point, you try to execute the statement
160 read(10,'(a4,i2,a6,i1,a4,i2,a6,i1,f12.6)')du1,b,du2,c,du3,d,du4,e,r
while the input file contains
obviously, your program does not like that.
The inelegant solution that comes to my mind is to first read the entire file as text, counting how many AS and BS data there is. Then reread as numbers, skipping text lines. There is probably a more clever way to it, but that should do it.
And please, please remove the gotos! Having a do while that includes a goto is particularly ugly: at least use an if-then
Thank you Dr. Claude for the suggestion.. I used that idea and now it seems to work very nicely for the entire data set. :) :)
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
