Does the Limit of 3xy/((x^2)+(4y^2)) as (x, y) Approaches (0,0) Exist?
  • Thread starter Thread starter manjum423
    Limit Variables
The limit of the function 3xy/((x^2)+(4y^2)) as (x, y) approaches (0,0) does not exist. Evaluating the limit by substituting y=x yields a value of 3/5, while substituting x=0 or y=0 results in 0. A robust approach to such problems involves testing various paths, such as y=kx or using polar coordinates, where x=2rcosθ and y=rsinθ, to analyze the limit's behavior more generally.
  • Understanding of multivariable limits in calculus
  • Familiarity with polar coordinates and their application in limits
  • Knowledge of substitution methods in limit evaluation
  • Basic algebraic manipulation skills
  • Learn about evaluating limits in polar coordinates
  • Study the method of approaching limits along different paths
  • Explore the concept of continuity and its relation to limits
  • Investigate the epsilon-delta definition of limits for multivariable functions
Students studying calculus, particularly those focusing on multivariable calculus and limit evaluation techniques, as well as educators seeking to enhance their teaching methods in this area.
manjum423
Evaluate the limit or prove that it does not exist..
f(x,y) -> (0,0)
3xy/((x^2)+(4y^2))
The attempt at a solution:
Set x to 0 and you get 0
set y to 0 and you get 0
set y=x and you get 3x^2/5x^2 = 3/5
This means that limit does not exist.
Is this correct?
If this is correct, how do you know that you have to set y=x? Is there a generic approach to these kinds of problems?
Thank you for taking the time to read this and for your help.
welcome to pf!
hi manjum423! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
Is this correct?
completely :smile:
you try y = kx first (for constant k),
if that doesn't work, try y = kxn
if that doesn't work, assume the limit exists, and try to prove it!
alternatively, use polar-ish coordinates, eg x = 2rcosθ, y = rsinθ, giving … ? :wink:
f(x,y) -> (0,0)
3xy/((x^2)+(4y^2))
Is this correct?
Hello manjum423 . Welcome to PF !
We do like you to use the supplied homework template.
You seem to have some difficulty writing you problem. It appears that you problem is something like:
Lim(x,y)→(0,0) 3xy/((x2)+(4y2))
Which can be displayed more nicely using LaTeX.
##\displaystyle \lim_{(x,y)\to(0,0)} \frac{3xy}{(x^2)+(4y^2)}##
Your solution is correct.
For your problem, the method you used works fine.
You could make it a bit more general by approaching the origin along the arbitrary line , y = mx .
That method doesn't always work either.
One pretty good scheme is to change to polar coordinates. Then only one variable, r, goes to zero. The other, θ, remains arbitrary.
