Need help, mechanics problem with pulleys and tensions
  • Thread starter Thread starter Sleepycoaster
    Mechanics Pulleys
The discussion focuses on solving a mechanics problem involving a pulley system with two masses: m1 (4kg) and m2 (2kg), along with a pulley mass of 2.6 kg and a rotational friction of 0.51 Nm. The user initially calculated an impossible acceleration of 84 m/s² for m1, which exceeds gravitational acceleration. Upon reevaluation, the correct acceleration was determined to be 2.68 m/s² after adjusting the signs in the equations governing the tensions and forces acting on the masses.
  • Understanding of Newton's laws of motion
  • Familiarity with rotational dynamics and torque
  • Knowledge of moment of inertia calculations
  • Basic algebra for solving equations
  • Review the principles of rotational dynamics in physics
  • Study the concept of tension in pulley systems
  • Learn how to calculate moment of inertia for different shapes
  • Explore advanced problems involving multiple masses and friction in mechanics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of pulley systems and tension analysis.
Sleepycoaster
I've already tried this problem but yielded an impossible answer:
We have a pulley with a mass-less rope attached to two masses hanging off each side of the pulley:
-m1 (4kg), suspended 1m off the ground
-m2 (2kg), on the ground
The mass (M) of the pulley is 2.6 kg
The rotational friction of the pulley is given as .51 Nm
The radius of the pulley is .085
How long will it take for the 4kg mass to hit the ground once the masses are released?
Moment of inertia (I) = (1/2)(mass)(radius)2
Torque (τ) = (moment of inertia)(angular acceleration)
Angular acceleration (α) = acceleration of point on outside edge of pulley / radius
I defined moving the pulley so that m1 falls as "positive" rotation and angular acceleration.
Regarding mass one,
Fnet = m1g + T1 = ma
T1 = m1a - m1g
For mass two,
Fnet = - m2g + T2 = ma
T2 = m2a + m2g
τnet = I α
τ(from tension) - τ(from friction) = ((1/2) M r2) (a / r)
T1r - T2r - .51 = (1/2)(2.6)(r)(a)
T1 - T2 - .51/r = (1/2)(2.6)(a)
m1a - m1g - m2a - m2g = 1.3a
a(m1 - m2 - 1.3) = m1g + m2g
a(4 - 2 - 1.3) = 39.2 + 19.6
a = 84
An acceleration greater than the acceleration due to gravity would be impossible for mass one.
Would any please check what I did wrong? Thank you!
Sleepycoaster said:
Regarding mass one,
T1 = m1a - m1g
Check the sign of the tension.
-m1a + m1g - m2a - m2g = 1.3a
a(-m1 - m2 - 1.3) = -m1g + m2g
a(-4 - 2 - 1.3) = -39.2 + 19.6
a = 2.68
That was the problem. Thanks!
  • · Replies 34 ·
  • · Replies 17 ·
