Why self focusing at high densities?
  • Context: Graduate
  • Thread starter Thread starter Kidphysics
    Self
The discussion revolves around the phenomenon of self-focusing at high intensities, particularly focusing on the relationship between the index of refraction and the intensity of radiation. Participants explore the underlying principles and effects related to high-intensity self-focusing.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant suggests that self-focusing is related to the index of refraction being directly linked to radiation intensity.
  • Another participant clarifies that the index of refraction is influenced by the square root of the dielectric constant, which is affected by material polarization under electric fields.
  • A participant explains that at high electric field intensities, non-linear effects occur, leading to increased polarization and a higher dielectric constant, which in turn affects the index of refraction.
  • A later reply expresses gratitude for the clarification and seeks further understanding of the relationship between the index of refraction and the square root of the dielectric constant.
Participants do not reach a consensus on the fundamental reasons behind the relationship between the index of refraction and the dielectric constant, as further questions remain unresolved.
The discussion includes assumptions about the behavior of materials under high electric fields and the nature of non-linear effects, which are not fully explored or defined.
Kidphysics
I understand it has something to do with the index of refraction being directly related to the intensity of radiation, but on a more fundamental level, why?
Science news on Phys.org
What are you talking about?
The index of refraction depends on the square root of the dielectric constant, which describes how a material polarizes when there are electric fields present. Polarization is an effect where electrons and nuclei are pulled apart. If the intensity of the electric field becomes very high there are non-linear effects and often once the electrons are pulled far from the nuclei they can be moved more easily leading to a higher dielectric constant and thus a larger index of refraction.
Thank you very much for the reply. I should have been more clear from the start. Your last sentence really helped me out and makes sense. My only remaining question is exactly how and why does the index of refraction depend on the square root of the dielectric constant..
  • · Replies 32 ·
9K
