Entropy For Irrevesible Process
  • Thread starter Thread starter Point Conception
    Entropy Process
The problem involves two aluminum cubes with different initial temperatures exchanging heat, leading to a change in their respective entropy values. The specific heat of aluminum is provided, and the task includes evaluating the entropy change during this irreversible process.
  • Participants discuss the evaluation of the integral of dQ/T for both the hotter and cooler objects, questioning the correctness of their calculations and assumptions regarding temperature during the heat exchange.
There is an ongoing examination of the evaluations made by participants regarding the entropy change and the application of the Clausius inequality. Some participants have provided insights into the temperature assumptions at the interface and the implications for the calculations.
Participants note that the heat transfer occurs in an irreversible manner and question the definitions of temperature during this process. There are also discussions about the assumptions regarding the thermal conductivity of the interface between the cubes.
Point Conception
Two 100g Aluminum cubes with T1 = 80° C and T2 = 20°C
Specific heat of Al is .22 cal/g/°C. The cubes are placed in contact and in short period of time
a quantity of heat, dQ , is transferred from T1 cube to T2 cube.
The cubes temperatures now are 75°C and 25°C. After a little math : dQ = 640 Joules
The total entropy of the two cubes before dQ was: 22.3 J/K and after dQ was 27.5 J/K
S2-S1 > ∫12 dQ/T
ΔS = 5.2 J/K > ∫12 dQ/T This should be evaluated :
ln dQ/T - ln dQ/T . The question on this is what are the T values here ?
Is it necessary to do two evaluations, one for hotter object and another for cooler object ?
S2-S1 = 5.2J/K
For hotter object ln 460 J/348K - ln 460J/353K = .01
For cooler object ln 460J/293K - ln 460J/298K = .02
Throughout the heat interchange, the temperature at the interface between the two cubes was 50C = 323 K. For an irreversible processes, if you are evaluating dQ/T for testing the Clausius inequality, you use the temperature at the boundary (interface). What was the integral of dQ/T for the hotter body? What was the integral of dQ/T for the colder body? What was the sum of these? How does that compare with the actual entropy change?
In the attempt of solution above is the evaluation of integral for hotter and cooler object correct ?
Total entropy change was + 5.2J/K
dQ/T for 323 K = 640 J/323K = 1.98 J/K
The inequality certainly holds , my question is whether I evaluated the two integrals correctly
with temperatures before and after dQ for both objects.
S2-S1 = 5.2J/K > 1.98 J/K (.03 )
No. For the hotter body, the dQ/T is -640/323 = -1.98. For the colder body dQ/T is +640/323 = +1.98. So, the total dQ/T for both bodies is zero. This is the value that you are supposed to compare with the sum of the actual entropy changes for the two bodies, which is
[tex]ΔS=mC_v(\ln (348/353)+\ln (298/293))[/tex]
With m = mass = 200g and Cv= specific heat Al = .22cal/g/C
ΔS = 200g*.92J/g/C * ln 348/353 + ln 298/293 = .48J/K
Good news , with math correction total entropy change for both objects S2 - S1 =
27.54J/K - 27.11J/k = .43J/K This value ( see work below ) is very close to above value
arrived at independently
Example for entropy , Q/T, for 100g object at 80 C , specific heat = .92J/g/C before dQ , S1
100g*80 C * .92J/g/C = 7360 J/353K = 20.84J/K + 6.27J/K for 20c object = 27.11J/K
ΔShot=92ln(348/353)=-1.05 J/K
ΔScold=92ln(298/293)=+1.55 J/K
(dQ/T)hot=-(92)(5)/323=-1.43 J/K
(dQ/T)cold=+(92)(5)/323=+1.43 J/K
The inequality must be satisfied not only for the system of two masses as a whole, but also for each mass individually. For the system as a whole,
ΔShot+ΔScold=-1.05 +1.55=0.50 J/K
(dQ/T)hot+(dQ/T)cold=-1.43+1.43=0 J/K
For the hot mass:
-1.05>-1.43
For the cold mass:
1.55>+1.43
As I said in the other forum, you are generally right that T may not even be defined during an irreversible process. I think here you are supposed to assume that the thermal bridge between the two cubes has much lower heat conductance than the aluminium blocks. Then the temperature within the blocks is homogeneous and you can relate it to dQ=C_v dT.
Not really. If the interface is infinitely conductive, then, by symmetry, the temperature at the interface would have to be 50 C throughout the heat exchange in this problem. If you could not be sure what the temperature at the interface would be in any irreversible process, then the temperature in Clausius' inequality would be meaningless, except for a reversible process, in which case the equality would apply.
Chet
Chet
I have not seen the Clausius inequality used in this way. The Clausius inequality relates to a cyclical process.
Since entropy is a state function, when the system returns to its original state there is no change in entropy: ΔSsys = ∫dQrev/T = 0.
However, if the cycle is not reversible ∫dQ/T ≤ 0 over the entire cycle where dQ is the actual heat flow into/out of the system (ie. this is strictly a path function, not a state function). This is because for a given amount of heat flow into the system, less work is done than in the reversible case so there is more heat flow out of the system to the cold reservoir than in the reversible case. This makes ∫dQ/T < ∫dQrev/T.
AM
AM
The form of the Clausius inequality that I am used to is
[tex]dS≥dQ/T[/tex]
There have been numerous recent references to this form of the Clausius inequality on PF.
Chet
9K
