Calculating Length of Wire for Horseshoe Electromagnet
  • Context: Undergrad
  • Thread starter Thread starter 215
The discussion focuses on calculating the length of wire needed for a horseshoe electromagnet, specifically one that is 4.1 cm long and 3.8 mm thick, using wire with a thickness of 0.130 mm and requiring 1600 windings. The calculation involves determining the number of windings per layer, which is approximately 315.385, and the impact of wire thickness on the overall length. The equation proposed is (3.8 + 0.0130*n*315.385) + rest, where 'n' represents the number of layers. The conversation also addresses the complexities introduced by non-uniform winding and the need to account for additional wire length due to the thickness of each layer.
  • Understanding of electromagnet design principles
  • Basic knowledge of geometry and mathematical equations
  • Familiarity with wire specifications and measurements
  • Experience with calculating layers and windings in coil design
  • Research "Electromagnet wire winding techniques" for best practices
  • Explore "Calculating wire length for coil windings" for detailed methodologies
  • Learn about "Non-uniform winding effects on electromagnet performance"
  • Investigate "Layered coil design in electromagnets" for advanced calculations
Engineers, hobbyists, and students involved in electromagnet design, coil winding, and electrical engineering applications will benefit from this discussion.
215
I am trying to make an mathmatical equation which can calculate the length of the wire, which is wounded around a a horseshoe electromagnet.
The horseshoe magnet is 4.1 cm long, and 3.8 mm thick.
The thickness of the wire is 0.130mm
I know that the electromagnet need 1600 windings
Which mean that on each layer there can be 4.1/0.0130 = 315.385 winding.
Which means that for eachs 315.385 winding must the Diameter become 0.130mm thicker.. right?
So the equation must be
(3.8+0.0130*n*315.385) + rest
Where n is the numbers {n,0,5}
Would this equation also be true if the wire isn't uniformly wounded?
I agree with the every 315.385 winding calculation in principle, but I'm not sure if the .385 portion is really meaningful. You need to figure out how long the wound up wire is, which is slightly more than doing 315.385 circles around the magnet because you're moving along the magnet slowly as well (you can figure out how fast it moves up the magnet). In particular this is a function of how thick the magnet is and how thick the wire is. You know there are going to be 1600 windings so there are going to be 1600/315 = 5+ a little extra layers.
At this point, for each additional layer to find out how much wire is used to put down the wire, you need to use the thickness of the new layer.
If the wire is not uniformly wound, how are you envisioning it being wound around the magnet?
I would think that the rest is the most inportant, since it is the thickest layer, and therefor will length of the wire be greatest here..
What i mean about not being uniformly is that after the first layer, the windings will not be stacked nicely as it was during the first round, mostly because some areas are easier to wind that others, which makes each layer will not be stacked above each one, I assume most of them must cross the previuos layer line..
One thing it certain.. the windings number is constant..
  • · Replies 17 ·
10K
