Statistics expectation problem involving circle.
The discussion revolves around a statistics problem involving the expectation of a function derived from a circle's geometry. The original poster is tasked with expressing a variable X as a function of an angle θ, which is uniformly distributed over the interval [0, 2π], and subsequently computing the expected value E(X).
  • Participants discuss the relationship between the variable X and the angle θ, exploring the use of trigonometric identities to express X. There are inquiries about the probability density functions and how to derive E(X) from the known distribution of θ. Some participants suggest using integrals to express E(X) in terms of θ, while others question the boundaries and the nature of the distributions involved.
The conversation is active, with participants providing insights and corrections regarding the definitions and calculations related to expectation. There is a recognition of the need to express E(X) in terms of the distribution of θ, and some participants have confirmed the correctness of certain expressions while others continue to seek clarification on the implications of their findings.
Participants are navigating through the definitions and properties of expected values, particularly in the context of transformations of random variables. There is an ongoing exploration of assumptions regarding the distributions involved and the implications of the uniform distribution of θ on the derived variable X.
peripatein
Hi,
A circle of radius r is as shown in the attached diagram. I am asked to first express X as a function of θ, then to compute E(X). It is also stated that θ obeys U[0,2π].
Through simple trigonometry I have found X = 2rsin(θ/2). As θ distributes evenly, I know that the density of θ should be 1/2π. What is the density of x then? Am I supposed to simply substitute 2arcsin(x/2r)? Or should it be approached by first computing E(θ) and trying to hence infer E(X)?
I'd appreciate an advice.
hi peripatein! :smile:
look at the definition
if X(θ) is a function of θ, and if the distribution of θ is f(θ),
then what is the definition of E(X) ? :wink:
The definition of E(X) is integral [would the boundaries be 1 to 2r?] x*f(x) dx, where f(x) is the probability density of X. Is this correct?
yees, but it's f(θ) that you know, not f(x) …
so what is E(X) expressed as an integral over θ ? :smile:
E(X) = ∫(2rsin(θ/2)/2π)(rcos(θ/2))dθ from 0 to 2π?
no
stick to the definition for the moment …
what is the definition of E(X) if X = X(θ), and the distribution of θ is f(θ) ?
I am not sure, tiny-tim :-(.
Should I look for the inverse function of X(θ)?
I mean, the definition reads E[g(X)] = integral (from -inf. to +inf.) g(x)f(x)dx. I understand that as E[θ(X)] = θ(X)*f(x)dx. I am probably mistaken, yet I am not sure how to approach it.
Here's another attempt, which makes not much sense to me but for the sake of trying: might it be E(X) = int X(θ)*f(θ)dθ?
peripatein said:
IHere's another attempt, which makes not much sense to me but for the sake of trying: might it be E(X) = int X(θ)*f(θ)dθ?
yes, that's correct …
E(X) = ∫ X(θ) f(θ) dθ
… this is exactly the same as the definition you mentioned earlier, ∫ x f(x) dx, but using the distribution of θ rather than the distribution of x (remember, the two f's are different!) :smile:
so in this case, E(X) = ∫ 2rsin(θ/2) f(θ) dθ,
which is … ? :wink:
4r/pi?
How may I now determine whether X obeys an even distribution U?
show how you got it :confused:
Well, shouldn't it be E(X) = ∫ 2rsin(θ/2) f(θ) dθ = ∫ (r/pi)sin(θ/2) dθ between 0 and 2pi?
correct :smile:
it obviously doesn't
θ is evenly distributed, so sinθ/2 isn't
(why are you asking? doesn't the question only ask for E(X) ? :confused:)
Now, the second part of that question, which is not related to the first, asks for a proof that
∫ (from 0 to ∞) xne-x dx = n! for every n > 0, and the hint is to find a recursive argument for In and an initial condition.
I have found In = (In + 1 + xne-x + nxn-1e-x) / (n(n-1)), where x changes from 0 to ∞, but am not sure how to proceed. Could you advise?
(how did you get that ?? :confused:)
anyway, you shouldn't have any x's in the equation
x is a dummy variable, the only "real" variable is n​
Well, integration by parts, twice. Setting the original integral to be In, I let u = xn and dv be e-x. In the second integration by parts I let u = xn-1 and dv = e-x.
Does that make more sense now? Is that how it is to be handled? The boundaries should be between 0 and infinity, but I don't know how to incorporate that into the expression (I mean, what do you get for (xne-x + nxn-1e-x) between 0 and inf.? How do you evaluate that?
why not just once? :confused:
i] what is xne-x when x = 0 ?
ii] what is (the limit of) xne-x when x = ∞ ?
You're right, silly me! A single integration by parts led me to the right answer: In+1 = (n+1)In.
Now, suppose I define f(x) = (xne-x)/n!. I have found E(X) = n + 1 and V(X) = 0.
Would you please confirm that?
yes that looks correct :smile:
and V(X) = 0.
what is V(X) ? :confused:
Variance (=E(x^2) - (E(x))^2)
Is it not zero in this case?
no :confused:
how did you get E(x2) ?
My bad, I made a mistake along the way. How's the following:
E(X2) = ∫ (from zero to infinity) (x2xne-x)/n!dx, right? And that is In+2/n!, which is in turn (n+2)(n+1), is it not? Now, (n+2)(n+1) - (n+1)2 = n+1 = Var(X). Is it correct now?
yes! :smile:
you see now how important it is to write everything out carefully? :wink:
Yes, tiny-tim, thank you very much! :-)
  • · Replies 18 ·
