How Do You Calculate the Magnitude of a Filter Response?
The discussion revolves around calculating the magnitude of a filter response defined by the equation F(w) = a / [1 - be^(-jwT)], focusing on the mathematical steps involved and the correct interpretation of complex numbers in the context of magnitude calculation.
  • Homework-related
  • One participant presents the filter response and attempts to derive its magnitude, expressing difficulty in eliminating sine terms.
  • Another participant suggests that the magnitude should be calculated using the formula √(Real² + Imag²), indicating that the imaginary unit does not factor into the magnitude itself.
  • A participant challenges the correctness of a proposed answer, asserting that it is incorrect without providing a definitive alternative.
  • Another participant questions the derivation of a specific expression for the magnitude, emphasizing that an imaginary component should not be present in the final magnitude calculation.
  • There is a reference to a general formula for calculating the magnitude of a complex fraction, which includes real and imaginary components.
Participants express disagreement regarding the correctness of the proposed answers and the method for calculating the magnitude, indicating that multiple competing views remain unresolved.
There are unresolved mathematical steps and assumptions regarding the treatment of complex numbers in the context of magnitude calculation.
jmher0403
where a and b are constants
Find the magnitude of this filter response
e^(-jX) = cos(X) - isin(X)
the answer is a/ √[1-2bcos(wT) + b^2*cos^2(2wT)]
but I can't seem to get rid of sines.
= a / [ 1 - b(cos(wT) - isin(wT) ]
= a / [1 - bcos(wT) + ibsin(wT)]
|F(w| = √{ a^2/ [1 - bcos(wT) + ibsin(wT)]^2}
= a /√[1-2bcos(wT) + b^2*cos^2(wT) + i 2bsin(wT) - i 2b^2*sin(wT)cos(wT) -b^2*sin^2(wT)]
Can anyone point me at the right direction??
I think you'll find that when determining the magnitude, you take √[/size]( Real^2 + Imag^2 ). The i operator itself does not appear in the magnitude term.
Where did you get this from? It's not correct.
Where did this come from? Makes no sense, and you can't have an imaginary component in a magnitude.
In general, given (a + jb)/(c + jd), a thru d real, magnitude = √(a2 + b2)/√(c2 + d2).
Plus, miles is right, the given answer is incorrect.
  • · Replies 20 ·
