Acceleration of a system with 2 Blocks and a Wedge
The problem involves a system with two blocks and a wedge, focusing on the dynamics of Block B on Wedge A and the interactions between them. The scenario includes considerations of mass, friction, and acceleration, with the goal of determining the accelerations based on varying coefficients of friction.
  • Participants discuss the forces acting on Wedge A and question whether the acceleration of the wedge is the same as that of Block B. There is an exploration of using different axes for analysis and the implications of such choices on understanding the system.
The discussion is ongoing, with participants sharing their thoughts on the forces involved and the appropriateness of different coordinate systems. Some guidance has been offered regarding the clarity of using different axes, but no consensus has been reached on the best approach.
Participants are considering the effects of friction and the relationship between the accelerations of the blocks and the wedge. There is uncertainty regarding the assumptions about the motion of the blocks and the wedge, particularly in relation to their accelerations.
goukishin
Block B of mass 10 kg is initially at rest as shown on the upper surface of a 20-kg wedge A which is supported by a horizontal surface. A 2-kg block C is connected to block B by a cord which passes over a pulley of negligible mass. Using computational software and denoting by m the coefficient of friction at all surfaces, use this program to determine the accelerations for values of m $ 0. Use 0.01 increments for m until the wedge does not move and then use 0.1 increments until no motion occurs.
ƩF = ma
Tc/Tb = e(μ x β) (In this case β = 120*pi/180
Taking each block as a system, finding Tc then Tb in terms of μ
Assuming the acceleration of Block C is the same as the acceleration of block B
Stuck at studying Wedge A. What are the forces acting on it and the equations?
Is the acceleration of the wedge the same as the acceleration of B?
What forces do you think are acting on it?
If B is sliding on A, it will have a different acceleration; otherwise it will be the same.
Can we chooses different axes to study Block B and wedge A ?
You can, but it might be confusing, particularly for anyone trying to check your work.
Well no, it is not confusing, it's the opposite. When we choose different axes according to the position of each block, it is much easier to find the Normal force acting on the system and the acceleration since a(y) becomes zero. But since Block B is in contact with the wedge, I wonder if that's allowed. And I really doubt it.
Sounds like you and I mean different things by 'using different axes'. pls post your working so that I can get some idea of what you're doing.
  • · Replies 25 ·
