Rashba effect due to the external electric field
The discussion centers on the Rashba effect, a spin-orbit interaction phenomenon that arises when an external electric field is applied to a structure. Participants clarify that the Rashba effect occurs because the traveling electron perceives electric fields as magnetic fields, which interact with the electron's spin. The external electric field polarizes atoms in the crystal structure, enhancing the effective magnetic field experienced by the electrons in the conduction band. This results in the emergence of the Rashba term in 2D structures perpendicular to the electric field.
  • Understanding of spin-orbit interaction in quantum mechanics
  • Familiarity with electric fields and their effects on atomic structures
  • Knowledge of crystal structures and their electronic properties
  • Basic principles of quantum mechanics and electron behavior
  • Research the mathematical formulation of the Rashba effect in quantum mechanics
  • Study the impact of external electric fields on electronic band structures
  • Explore the role of surface potentials in the Rashba effect
  • Investigate applications of Rashba effect in spintronic devices
Physicists, materials scientists, and engineers working in the fields of quantum mechanics, semiconductor physics, and spintronics will benefit from this discussion.
Nemanja989
Hi, I am modeling structure that takes into account Rashba effect, and I am not sure what is the mechanism that causes Rashba effect to appear.
On wikipedia Rashba is described as spin-orbit interaction effect which appears because electron is orbiting around nucleus and electron see nucleus orbiting around from where we get effective magnetic field that further on interact with spin of the electron.
What confuses me is why Rashba appears after we apply external electric field on the structure? Does external field somehow polarize atoms in crystal structure and therefore electrons in conduction band "see" more clearly electric field of the nucleus from where we get Rashba effect? Or is it something else?
thanks in advance :)
Where does it say that? That is quite misleading.
Basically, one can use the traditional hand waving argument: a traveling electron will perceive electric fields as magnetic fields (which the electron spin can couple to). In the simplest case, a lone Hydrogen atom, the field is entirely due to the nucleus. This is the usual (atomic) spin-orbit interaction.
However, in more complicated structures and situations, you get several different contributions to the electric field (in addition to the nuclear field). There is, in principle, a periodic crystal potential, surface potentials, external electric field etc. For a 2D structure perpendicular to the electric field, the term due to the electric field is just called the Rashba term.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 24 ·
