Calculating Angular Acceleration for a Solid Cylinder on a Frictionless Bearing
The discussion revolves around calculating the angular acceleration of a solid cylinder that pivots on a frictionless bearing, with a string exerting a downward force equivalent to the weight of a suspended mass. Participants explore the relationships between forces, torques, and angular acceleration in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss free body diagrams and the application of Newton's laws. There are attempts to equate forces and torques, with some questioning the assumptions about the forces acting on the cylinder and the hanging mass. Others explore the conversion between linear and angular quantities.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have offered guidance on the relationships between torque, moment of inertia, and angular acceleration, while others are still clarifying their understanding of the forces involved.
There are indications of confusion regarding the nature of the forces acting on the cylinder, particularly whether the force exerted by the string is equivalent to the weight of the hanging mass. Additionally, participants are navigating the transition from linear to angular acceleration and the implications of their calculations.
Punchlinegirl
M, a solid cylinder (M=1.99 kg, R=0.133 m) pivots on a thin, fixed, frictionless bearing. A string wrapped around the cylinder pulls downward with a force of F which equals the weight of a 0.830 kg mass, i.e, F=8.142 N. Calculate the angular acceleration of the cylinder.
I tried drawing a free body diagram and setting the forces equal to ma.
F_n- mg-F_t= Ma_y
since a= 0, F_n= Mg + F_t
torque= RF_t sin 90= Ia
RF_t=Ia
I=(1/2)MR^2
F_t= (1/2)MRa
mg-ma=(1/2)MR(a/R)
(1/2M +m)a= mg
a=mg/ (1/2 M=m)
I plugged in my numbers, but I think the equation is wrong. Help?
From the problem statement:
{String Tension} = S
{Mass of Suspended Entity} = m = (0.830 kg)
{Weight of Mass} = W = (0.830 kg)*(9.81 m/sec^2) = (8.1423 N)
{Cylinder Mass} = M = (1.99 kg)
{Cylinder Radius} = R = (0.133 m)
{Cylinder Moment of Inertia} = I = (1/2)*M*R^2
{Cylinder Angular Acceleration} = α
For the suspended entity:
{Net Force} = ma =
= W - S
::: ⇒ S = W - ma ::: Eq #1
For the cylinder:
{Net Torque} = Iα = I*a/R =
= S*R
::: ⇒ S = I*a/R^2 ::: Eq #2
Equating Eq #1 and Eq #2:
W - ma = I*a/R^2
::: ⇒ a = W/{m + I/R^2}
::: ⇒ a = W/{m + (1/2)*M*R^2/R^2}
::: ⇒ a = W/{m + (1/2)*M}
::: ⇒ a = (8.1423 N)/{(0.830 kg) + (1/2)*(1.99 kg)}
::: ⇒ a = (4.46153 m/sec^2)
::: ⇒ α = a/R = (4.46153 m/sec^2)/(0.133 m) = (33.545 radians/sec^2)
Your first error is in assuming that the string exerts a force equal to the weight of the hanging mass. (If the force were equal, then the mass would be in equilibrium.) But it looks like you don't use this fact later on.
F_n- mg-F_t= Ma_y
For the cylinder, the only forces you need consider are those that create a torque. Thus the normal force (supporting the cylinder) and the weight of the cylinder are irrelevant; all that counts is the force F that the string exerts.
Applying Newton's 2nd law:
To the cylinder:
[itex]\tau = I\alpha[/itex] --> [itex]F R = I\alpha[/itex]​
To the hanging mass:
[itex]mg - F = ma[/itex]​
RF_t=Ia
I=(1/2)MR^2
F_t= (1/2)MRa
So far, so good. (a is really alpha)
mg-ma=(1/2)MR(a/R)
(1/2M +m)a= mg
a=mg/ (1/2 M=m)
All good. I assume you meant to write: [itex]a = mg/(M/2 + m)[/itex].
Did you remember to convert to angular acceleration?
ok, i used the equation and tried converting to angular acceleration by using
a=alpha* r
and got the angular acceleration to be 3.87 rads/s^2, which isn't right...
Alpha is the angular acceleration, you are using your equation backwards :). Solve it for alpha and try it that way.
i have a similar problem to punchlinegirl, and i was wondering how do i find alpha from angular acceleration
Angular acceleration IS "α". You might be thinking of the following relationships:
{Angular Acceleration} = α =
= {Linear Acceleration}/R =
= a/R
{Angular Velocity} = ω =
= {Linear Velocity}/R =
= v/R
Also:
= 2*π*{Rotation Frequency} =
= 2*π*f
M=1.99 kg, R=0.133 m, F=8.142 N
I = .5MR^2, T(1) = r x F and T(2) = I x alpha.
Solve for I and then solve T(1) using F given and then once you have both plug into T(2).
The force is equal to the weight of a hanging mass. This doesn't mean that there is actually a mass hanging off of it, it means there is a constant force applied of 8.142N.
Once you see that the problem is simple.
You have the equation T=I*alpha
alpha is angular acceleration which is what you need so just solve for alpha.
alpha=T/I where T is the torque applied and I is the moment of inertia.
T = F*r (when torque is perpendicular)
T = (8.142N) (0.133m)
T= 1.083Nm
Now find I, since it is a solid cylinder
I=(1/2)Mr^2
I = (1/2) (1.99kg) (0.133m)^2
I = 0.0176 kg*m^2
now recall
alpha = T/I
alpha = (1.083Nm)/(.0176kg*m^2)
ALPHA = 61.5 rad/s^2
Good point! The problem never mentions a hanging mass, just a mass. I misread the problem. :redface:
  • · Replies 21 ·
  • · Replies 97 ·
13K
