Thread Closed
Constant Power and speed of particle relation
Share Thread Thread Tools
Mar29-05, 05:20 PM   #1
Arrow
Hello all
I encounter a difficulty solving most simple problem related to constant power and speed of particle the problem is as follows:
Express the speed (V) of a car given a constant power P , the mass of the car is m, the car travels distance x and it at first was at rest.
I assume initial speed and dist. is zero, if P is constant I can write it as P=FV so
V=P/F ; F=mA (where A is acceleration) here I feel there should be some integration but I don't know how to continue ?
Help will be appreciated!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Mar29-05, 05:30 PM   #2
Recognitions:
Homework Helper Homework Help
Why do they give you the distance "x"...?It requires a simple integration.
[tex]P=m\frac{dv}{dt}v [/tex]
Do u see how to derive [itex] v(t) [/itex]...?
Daniel.
Mar29-05, 05:38 PM   #3
No I'm not so good with diff. equations .!
Mar29-05, 05:50 PM   #4
Recognitions:
Separate variables and integrate with corresponding limits...
[tex] v \ dv =\frac{P}{m} dt [/tex]
Daniel.
Mar29-05, 06:11 PM   #5
Already made but the answer is given by x ,p ,m and factoring numbers !
I think DX/DT is needed ??/
Mar29-05, 06:22 PM   #6
Recognitions:
It can't."x" given in the problem is a number.I don't know why they gave it,though...
Daniel.
Mar29-05, 06:28 PM   #7
I can post the answer for you it goes like : v=(3xp/m)^(1/3)!!!!
The question is from Resnick Physics 1 4th edition chapter 7 problem 52 , I suppose the answer is correct .
Mar29-05, 06:38 PM   #8
Recognitions:
Okay the velocity is
[tex] v=\sqrt{\frac{2P}{m}} \sqrt{t} [/tex] (1)
Integrate wrt time & use the initial condition (t=0,x=0) to find
[tex] x=\frac{2}{3}\sqrt{\frac{2P}{m}} \ t^{\frac{3}{2}} [/tex] (2)
Eliminate "t" between (1) & (2) & u'll find your answer.
Daniel.
Mar30-05, 02:09 AM   #9
Thank you very much
I got it , good to know there are wise people out there.
Thread Closed
Thread Tools
Similar Threads for: Constant Power and speed of particle relation
Thread Forum Replies
Relation between speed in water and weight Introductory Physics Homework 1
2-D Waves: Relation of power with radius General Physics 4
relation between symmetry, charges and one-particle states Quantum Physics 1
relation between electron movement and power factor. General Physics 1
relation between cue ball and cue speed General Physics 7
