Safety- poly resin , MEKp my boss might be a butthead
  • Thread starter Thread starter Hydrangea
    Safety
This discussion centers on safety concerns regarding the handling of polyester resin and MEKP (Methyl Ethyl Ketone Peroxide) in a laboratory setting. The participant highlights the lack of a respirator despite the presence of a fume hood and references the Material Safety Data Sheet (MSDS) which indicates the necessity for protective gear when handling these chemicals. Key safety recommendations include wearing a NIOSH-approved respirator, goggles, and protective clothing to mitigate the risks associated with inhalation and skin contact with toxic substances.
  • Understanding of Material Safety Data Sheets (MSDS) and their importance in chemical handling
  • Knowledge of personal protective equipment (PPE) requirements for handling hazardous materials
  • Familiarity with OSHA regulations, specifically 29CFR 1910.134 regarding respirator use
  • Basic knowledge of polyester resin and MEKP properties and hazards
  • Research NIOSH-approved respirators suitable for handling MEKP and similar chemicals
  • Study OSHA guidelines on chemical safety and PPE requirements
  • Learn about the safe handling and disposal of polyester resin and MEKP
  • Review best practices for laboratory safety when working with volatile solvents
Laboratory technicians, safety officers, and anyone involved in the handling of hazardous materials, particularly those working with polyester resin and MEKP in industrial or research settings.
Hydrangea
On a side note, does anyone think it is crummy that I had to pour and mix polyester resin, MEKP , (fume hood available), while my boss took solvents and chemicals out of the fume hood for weighing etc? I was not provided a respirator, even though all the MSDS s and most forums indicate it is usual... :(
Chemistry news on Phys.org
Actually the MSDS says:
http://noracperoxides.com/msds/Norox_MEKP/MEKP-9_MSDS.pdf
If airborne concentrations are expected to exceed acceptable levels wear a NIOSH
approved air-purifying respirator with an organic vapor cartridge or canister. When
using respirators refer to OSHA’s 29CFR 1910.134
It also states that by inhalation it is moderately toxic, but a severe skin and eye irritant.
Since you had a fume hood the level of airborne concentration should have been acceptable.
From the MSDS, a greater worry would have been about a lack of both goggles for eye protection and protective clothing and gloves for skin protection, but since you did not mention that it seems not to have worried you or the items were available.
Not saying you are incorrect in feeling apprehensive. Perhaps discuss with your boss about aquiring resperators to be available, since when handling toxic material always expect the unexpected.
Right. Thank you re: skin contact, eye advice.
What about the polyester resin? I did read the thing. But I have been reading so many this last week I have tuned them out in a way. TMI.
Lol, yes: protective clothing donned. I wear spec.s, so I admittedly ought to have had on goggles over top. I have the bad habit of thinking the glasses are enough.
Now that you mention it, I am guilty of missing the forest- trees. I was cleaning up and a little bit of acetone splashed onto my face. Ick. My eyes were safe. Guess I hardly have room to complain-- one of those moments where you are embarrassed at your mistake so I ignore it.(wiped on my lab coat arm).
I guess it bugged me that she didn't seem to have issue with having the chemicals opened up and then started to pour the mekp on the open bench top . I know I shouldn't gripe because after all, "who amongst is perfect?" Like, I'm throwing stones from my glass house, when actually, I'm sure I've done all of the same. Deep breath!
Thanks for your response!
9K
