What Do Peaks in Gamma Radiation Absorption Data Indicate?
The discussion revolves around the interpretation of peaks in gamma radiation absorption data obtained from an experiment involving gamma spectroscopy. Participants explore the significance of different peaks observed in the data, particularly in relation to the thickness of the absorber material and the gamma source used.
  • Some participants inquire about the meaning of the peaks in the gamma radiation absorption data, questioning why there are high and medium-sized peaks.
  • One participant suggests that the x-axis may actually represent gamma energy rather than absorber thickness, while the y-axis corresponds to the counts detected in each energy bin.
  • Another participant points out that different gamma emitters, such as Co-60 and Cs-137, exhibit distinct peak patterns, with Co-60 having two gamma peaks.
  • There is a suggestion that the type of detector used, such as a sodium-iodide scintillator, could influence the resolution and appearance of the peaks.
  • Some participants express frustration over the lack of detail provided about the experiment, arguing that it hinders effective discussion and understanding.
Participants do not reach a consensus on the interpretation of the peaks, with multiple competing views and uncertainties remaining regarding the data and its implications.
There are limitations in the discussion due to missing details about the experimental setup, including the specific gamma source and the nature of the absorber. This lack of information may lead to misinterpretations of the data and responses.
M. next
After performing this experiment, we will get different peaks on the computer screen, where on x-axis lies thickness of the absorber and on the y-axis the nb of channels. What do these represent exactly? Why do we have a high peak and a medium sized one?
What are the significances of each?
Thanks.
Thanks.
Don't you think that it will be significantly clearer if you describe in detail the experiment (i.e. what material were you looking at), and actually show the graph of the data you are referring to?
Zz.
I didn't because I thought it is a known experiment.
So here's the graph, see attachment please.
And this is experiment aims as its title says absorption of gamma radiation by some absorber (lead for example) in order to measure its attenuation.
What we're changing through the experiment is the thickness of the absorber.
What I don't get is the peaks? Why do we have different peaks?
What is your gamma source (which isotope)?
What kind of detector are you using? I'm guessing a sodium-iodide scintillator, because it's cheap and easy to use in an undergraduate lab.
For all isotopes, similar graphs occur with different peaks. Am just asking why do different peaks appear? Am asking a theoretical question.
You were asked nicely - twice - to describe what you are doing. Making us guess is neither efficient nor polite.
I was referring to the particular picture that you attached.
Thank you jtbell.
So I guessed correctly, then? :wink:
Thank you but my question was not related to what of scintillator to be used. I was asking about the meaning of the peaks. What do they represent in general. That's why I said I was asking theoretical question and materials used didn't have to do with answer I thought. But thank you for your reply, jtbell.
Since you refuse to provide necessary details, this thread is closed.
Thanks.
It appears one is performing gamma spectroscopy. I doubt the x-axis is absorber thickness, but rather is related to the energy of the gamma. The y-axis should be the counts (gammas detected) in the corresponding channel (gamma energy bin) on the x-axis. So already, it seems one is misinterpreting the data presented.
The type of detector (NaI, GeLi or other) affects the resolution of the peaks.
When one mentions absorber, it is not clear if one is referring to the detector material, or some attenuator.
Some gamma emitters, e.g., Co-60, have two gamma peaks. The spectum in one's attachment appears to that of Co-60. Other radionuclides, e.g., Cs-137, emit one predominant gamma ray.
The detector will also respond to lower energy gammas from internal conversion, Compton effect, and pair production.
M. next said:
I didn't [give details] because I thought it is a known experiment.
It is dangerous to do this, because people may guess the missing details incorrectly. This causes people to give answers which may not be appropriate for your situation, wasting both your time and theirs.
We have seen it happen many times, that someone makes an incorrect guess about the questioner's situation, and then the questioner has to say "no, this is what it really was..." So we're not simply nit-picking.
  • · Replies 29 ·
  • · Replies 0 ·
