How can the expression for orthonormal states be simplified?
  • Context: Graduate
  • Thread starter Thread starter omoplata
    Simplifying States
The expression for orthonormal states can be simplified using properties of complex numbers and inner products. The transition from the first line to the second line in the equation involves recognizing that the terms involving the inner products can be expressed in terms of their real parts. Specifically, the equality 12 i ⟨φ_n | ψ_1⟩ ⟨φ_n | ψ_2⟩* = -12 i ⟨φ_n | ψ_2⟩ ⟨φ_n | ψ_1⟩* holds due to the commutative property of complex numbers and the definition of the complex conjugate. This simplification is valid and confirms the correctness of the solution.
  • Understanding of quantum mechanics terminology, specifically orthonormal states.
  • Familiarity with complex numbers and their properties.
  • Knowledge of inner product notation in quantum mechanics.
  • Basic grasp of real and imaginary components of complex numbers.
  • Study the properties of inner products in quantum mechanics.
  • Learn about the significance of orthonormal states in quantum systems.
  • Explore complex number operations and their applications in quantum mechanics.
  • Investigate the implications of normalization in quantum state representations.
Quantum physicists, students of quantum mechanics, and anyone interested in the mathematical foundations of quantum state representations.
omoplata
The following was written down as a solution to a problem,[tex] \begin{eqnarray}<br /> P(\alpha_n) & = & \frac{1}{25} \left[ 9| \langle \phi_n \mid \psi_1 \rangle |^2 + 16 | \langle \phi_n \mid \psi_2 \rangle |^2 + 12 i \langle \phi_n \mid \psi_1 \rangle \langle \phi_n \mid \psi_2 \rangle^* - 12 i \langle \phi_n \mid \psi_2 \rangle \langle \phi_n \mid \psi_1 \rangle^* \right]\\<br /> & = & \frac{1}{25} \left( 9| \langle \phi_n \mid \psi_1 \rangle |^2 + 16 | \langle \phi_n \mid \psi_2 \rangle |^2 + 2 \Re \left[ 12 i \langle \phi_n \mid \psi_1 \rangle \langle \phi_n \mid \psi_2 \rangle^* \right] \right)<br /> \end{eqnarray}[/tex]How do you get from the first line to the second line? How does [itex]12 i \langle \phi_n \mid \psi_1 \rangle \langle \phi_n \mid \psi_2 \rangle^* = - 12 i \langle \phi_n \mid \psi_2 \rangle \langle \phi_n \mid \psi_1 \rangle^*[/itex] ?
Is this solution wrong?
Here, [itex]\mid \psi_1 \rangle[/itex] and [itex]\mid \psi_2 \rangle[/itex] are two orthonormal states, while [itex]\mid \phi_n \rangle[/itex] is a normalized state, if that makes any difference.
The crucial observation is that
[tex]i { \langle \phi_n \mid \psi_1 \rangle } { \langle \phi_n \mid \psi_2 \rangle^* } = <br /> \left( -i { \langle \phi_n \mid \psi_1 \rangle^* } { \langle \phi_n \mid \psi_2 \rangle } \right)^*[/tex]
(because [itex](abc)^* = a^* b^* c^*[/itex] and [itex](a^*)^* = a[/itex], and because the brakets are complex numbers which commute).
Then it's easy to verify that for any complex number z, [itex]z + z* = 2 \Re[z][/itex].
OK. Got it. Thanks.
  • · Replies 29 ·
