Why does [HA]=[A-] halfway thru a titration?
  • Thread starter JeweliaHeart
  • Tags
    Titration
In summary, during a titration involving a strong acid or base, the reaction always goes to completion and the equivalence point is reached when moles of acid equal moles of base. The endpoint, where the indicator changes color, is usually very close to the equivalence point. At the halfway point, the concentrations of HA and A- are equal, resulting in a pH of pKa. However, the concentrations may not be exactly equal due to the acid dissociating on its own and the strength of the acid.
JeweliaHeart
68
I read somewhere that:
"During the course of a titration, an acid in solution reacts with a base in solution, and
when a strong acid or strong base is involved, this reaction always goes to completion..."
HA(aq) + OH- (aq) → A- (aq) + H2O (1)"
"At the equivalence point (which is the place where moles of acid = moles of base) the
titration is complete, no HA remains; and the only substances in the beaker are water, the
conjugate base, A-, and a spectator ion. The end point is the place at which the indicator
changes color. The endpoint and the equivalence point are not always identical, but they
are always very close."
"Halfway to the end point, half of the HA has reacted to become its conjugate base A- and
water. At that point, the concentrations of HA and A- are equal. When these
concentrations are equal, log [A-]/[HA] is zero and pH = pKa (see equation 4). It is clear
then that pKa can be read directly from the titration curve as the pH at the half-way point
of a titration."
So I understand most all of this, but one thing is bugging me:
Why does [HA]=[A-] halfway to the end point? Shouldn't the concentrations be equal to one another the whole time b/c they are both in the same volume of container and dissociate with the same molar ratio 1:1?
I must be totally misunderstanding something b/c that makes no sense to me.
Chemistry news on Phys.org
It is hard to pinpoint where you are making the mistake - but yes, you are wrong.
You start with just HA, so initially you have A- only from dissociation - so the concentrations are not equal as you suggest even before we start the titration. Then they mostly follow the stoichiometry - base reacts with the acid, so the amount of produced A- is more of less equal to amount of base added (with some minor differences caused by dissociation/hydrolysis), while concentration of HA is that of HA not yet neutralized. when you are halfway amount of base added is half of the amount of acid, so from stoichiometry [A-]=[HA].
Oh my gosh. Thank You. It is crystal clear now.
So, and correct me if I'm wrong please,
[added base]=[conjugate base] throughout most of the reaction b/c the base combining with the acid leads to the formation of water and A-. And the minor differences in concentration are caused by the HA dissociating on its own, so technically the [A-] is a little higher than [OH-].
At the halfway point, the [HA]=[OH-], but since the [OH-] is roughly equal to [A-], then
[HA]=[A-].
Yes, you got it. One remark:
It actually depends on how strong the acid is. If it is very weak (say HCN, with pKa=9.31), conjugate base produced during neutralization will be a relatively strong Bronsted-Lowry base, reacting with water to produce HA and OH-, so it may happen that the concentration of HA will be actually higher than expected. If the acid is relatively strong (say trichloroacetic, pKa=0.7) concentration of HA is not even approximately equal to the concentration of base at midpoint, for typical titration concentrations it will be twice larger. But these are rather extreme cases.
There is a misunderstanding here. The statement "[HA]=[A-] halfway to the end point" is referring to the concentrations of HA and A- at the halfway point of the titration, not throughout the entire titration. At the beginning of the titration, the concentration of HA is much higher than A-, but as the titration progresses, HA is consumed and converted into A-. Therefore, at the halfway point, the concentrations of HA and A- are equal because half of the initial amount of HA has been converted into A-. This is also why the pH at the halfway point is equal to the pKa, as explained in the equation 4 mentioned in the text.
Additionally, the concentrations of HA and A- are not equal throughout the entire titration because as HA is consumed, the volume of the solution also changes. Therefore, the concentrations are not constant and will only be equal at the halfway point when half of the initial volume has been used.
It's important to note that this explanation is based on a strong acid-strong base titration, where the reaction goes to completion. In a weak acid-strong base titration, the concentrations of HA and A- will not be equal at the halfway point due to the presence of a buffer solution and the equilibrium reaction between the acid and its conjugate base.
1. Why does [HA]=[A-] halfway thru a titration?
This is known as the equivalence point in a titration, where the amount of acid (HA) is equal to the amount of its conjugate base (A-). This occurs because at this point, all of the acid has been neutralized by the base, resulting in an equal amount of acid and conjugate base.
2. How do you determine the equivalence point in a titration?
The equivalence point can be determined by using an indicator, which changes color at the point of equivalence. It can also be determined by using a pH meter or by calculating the moles of acid and base present at different points in the titration.
3. What factors can affect the equivalence point in a titration?
The strength of the acid and base, the concentration of the acid and base, and the volume of the acid and base can all affect the equivalence point. Additionally, the presence of impurities or the use of incorrect procedures can also impact the equivalence point.
4. How does the pH change during a titration?
The pH starts off low at the beginning of the titration, as there is a high concentration of acid. As the titrant (base) is added, the pH gradually increases until it reaches the equivalence point, where it levels off at a neutral pH. After the equivalence point, the pH continues to increase as the excess base is added.
5. What is the purpose of a titration in scientific experiments?
Titration is used to determine the concentration of a solution, particularly of acids and bases. It is also used to determine the strength of an acid or base, as well as to identify unknown substances by comparing their titration curves to known substances. Titration is an important tool in many scientific fields, including chemistry, biology, and medicine.
  • Chemistry
  • Chemistry
