Relativity situation. Questions.
  • Context: Graduate
  • Thread starter Thread starter hedons
    Relativity
The discussion centers on the scenario of a bomb with a trigger input sample at 99.99% of its critical mass, aboard a spaceship accelerating to 99.9% of the speed of light. It concludes that the bomb will not detonate, as the trigger sample does not change in its own rest frame despite the high velocity. The conversation emphasizes the importance of understanding relativistic mass versus rest mass and highlights that momentum remains consistent across different frames of reference. Key concepts include the role of the mass measuring device (MMD) and the relativistic momentum equation P = mvγ.
  • Understanding of relativistic physics concepts
  • Familiarity with the equation for relativistic momentum (P = mvγ)
  • Knowledge of rest mass versus relativistic mass
  • Basic principles of frames of reference in physics
  • Research the implications of relativistic mass in high-speed scenarios
  • Study the Usenet Physics FAQ on mass and velocity
  • Explore the concept of frames of reference in detail
  • Learn about the effects of acceleration on physical objects in motion
This discussion is beneficial for physicists, students of physics, and anyone interested in the implications of relativity on mass and momentum in high-speed environments.
hedons
Situation:
You have a bomb which will detonate if the input sample on its trigger is of a certain mass (we'll call this the critical mass).
The trigger input sample has a mass equal to 99.99% of the critical mass.
A person takes this device on spaceship which begins to accellerate towards its top speed of 99.9% the speed of light.
Will the bomb detonate?
Thanks,
Glenn
As long as you do not accelerate too quickly (which creates G-forces) then no, the trigger input sample doesn't change in its own rest frame. Remember, velocity is all relative anyway--even if the bomb is at rest on earth, it is already moving at 99.99% of light speed in some other frame. Also, it should be noted that many physicists don't like to use the concept of "relativistic mass" at all, instead just talking about rest mass (which never changes) and relativistic momentum--see Does mass change with velocity? from the Usenet Physics FAQ.
The problem is in considering the mass measuring device (MMD). For someone in motion relative to the bomb, everything in the bomb frame (bomb and MMD) has a momentum equal to:
[tex]P = m v \gamma[/tex]
So the momentum of everything in the bomb frame (relative to the moving frame) is increased by the same factor, so any device which measured mass based on collisions would operate exactly the same as it would in the bomb's rest frame.
  • · Replies 32 ·
  • · Replies 36 ·
  • · Replies 75 ·
  • · Replies 0 ·
  • · Replies 24 ·
