Understanding Temperature: Definitions and Applicability in Everyday Life
  • Context: Graduate
  • Thread starter Thread starter fluidistic
    Temperature
The discussion revolves around the definition and applicability of temperature in both equilibrium and non-equilibrium states, exploring theoretical and practical implications in thermodynamics and everyday contexts.
  • Some participants assert that temperature is defined only for equilibrium states, referencing the definition from Callen's book.
  • Others propose that local thermodynamic equilibrium (LTE) allows for the extrapolation of temperature to kinetic systems, even when they are not in full equilibrium.
  • A participant questions whether internal energy (U) is also defined only for equilibrium states, suggesting that if entropy (S) is not well-defined, then U(S,V,n) cannot be either.
  • Some argue that internal energy can be defined in non-equilibrium states, as it is a more fundamental concept than entropy, which is contingent on equilibrium conditions.
  • There is a discussion about the continuity and differentiability of the entropy function, with references to literature that addresses non-equilibrium thermodynamics.
  • One participant mentions that temperature, in practical terms, is often understood as a measure of "degree of hotness," which can still yield values even in non-equilibrium situations.
  • Concerns are raised about the path-dependence of heat transfer (dQ) and its implications for the definitions of temperature and entropy in dynamic systems.
Participants express differing views on the applicability of temperature and internal energy definitions in non-equilibrium states, with no consensus reached on the implications of these definitions.
Participants note that the definitions of temperature and entropy may not hold in fully dynamic systems, and the continuity and differentiability of the entropy function are questioned in non-equilibrium contexts.
fluidistic
Today I've got rid of a lot of questions but one remains so far.
The definition of temperature I've seen in Callen's book is ##T=\left ( \frac{\partial U}{\partial S} \right ) _{V, \{ n_i \} }## (i=1, 2, etc.) where the entropy is defined only for equilibrium states.
Therefore if I understand well, T is also defined only for equilibrium states. However in the lab. or in everyday's life (meteorogolists), we all use temperature as if it was defined even for systems that are totally off from any thermodynamic equilibrium. How is that possible? Does it even make sense to talk about temperature for systems that aren't in thermodynamics equilibrium, i.e. systems that have not a well defined entropy?
Science news on Phys.org
You are correct- temperature is only defined in terms of systems in equilibrium. Using *local thermodynamic equilibrium* is why we can extrapolate to kinetic systems. Fully dynamic systems that violate LTE (turbulent flow and shock fronts, for example) do not in general have a well-defined temperature or entropy.
Thank you very much.
Does this also mean that U(S,V,n) is also defined only for equilibrium states or at a local viewpoint, only when there's no turbulent flow/shock fronts?
Are you defining 'U' as the internal energy, the total energy, or some other quantity? The internal energy density (that is, the total energy less kinetic and potential) is well-defined always via the Reynolds transport equation- as long as the density is well-defined, the internal energy is then well-defined.
The book defines it as the internal energy. That's the "U" that appears in the dependence of the entropy, S(U,V,n).
In principle one could always (if I'm not wrong!) get the dependence U(S,V,n) if one has beforehand the relation S(U,V,n). That's why I think that if S isn't well defined for some states, then U(S,V,n) isn't either.
That's a good point, but it requires that S(U,V,n) is invertible, which is not the case in thermodynamics. For example, while dU is an exact differential (dU = dQ - dW), dQ is not- it is path-dependent, and this is why you often see dU = δQ - δW. Thus the expression dS = δQ/T can be somewhat misleading in the context of thermodynamics (as opposed to thermostatics and thermokinetics), since 'T' may not be well defined.
So, if 'T' is not well defined, the expression dS = δQ/T means that S is not an exact differential either, so S(U,V,n) cannot be inverted to provide U(S,V,n).
Hmm I'm confused. My book says
Callen's book 1st ed. page 26 said:
The continuity, differentiability, and monotonic property imply that the entropy function can be inverted with respect to the energy and that the energy is a single-valued, continuous, and differentiable function of S, V, N1 ... ##N_r##
The function ##S(U,V,N_1...N_r)## can be solved uniquely for U in the form ##U(S,V,N_1...N_r)##
Sligthly before that, he mentions that S exists only for eq. states. This is why I thought that U cannot be defined if S isn't defined. And so the temperature isn't defined either for non equilibrium states.
No, this is not right. Energy is more basic notion than entropy - it was introduced in mechanics before entropy was. System has energy even in non-equilibrium states by assumption, since we believe in the law of conservation of energy.
Only for equilibrium states is the energy function of S,V,N.
Regarding the original question: the temperature in practice means "degree of hotness", measured by some thermometer. We always get some number, even if thermometer is in touch with body in non-equilibrium state.
Usually, for water in washing machine or air in weather forecast, the meaning of temperature is quite close to the thermodynamic temperature, since the medium in non-equilibrium state can be understood as a collection of small parts that are almost in equilibrium with spatially varying temperature and density of entropy. Then the relation between energy, entropy and temperature may hold approximately for each small enough constituting part, even if it does not hold for the whole system.
The issue is: when is the entropy function continuous, differentiable, and monotonic? For statics and kinetics, the entropy function meets these criteria. For the fully dynamic case, Jou, Casas-Vazquez, and Lebon's "Extended Irreversible Thermodynamics" has an excellent introductory sequence leading up to non-equilibrium equations of state. This paper discusses the idea of 'uncompensated heat' in nonequilibrium processes:
http://pre.aps.org/pdf/PRE/v51/i1/p768_1
And this
http://www.google.com/url?sa=t&rct=...zkufUlZHf0e0euRAPNqkZcw&bvm=bv.46471029,d.aWc
Also has a useful introduction. AFAIK, there is no clear definition of entropy for far-from-equilibrium systems, or entropy flux relating to far-from-equilibrium processes.
