Calculate L using Omega, Lo = 16, and h = 1.5
  • Thread starter Thread starter eddievic
The discussion revolves around finding the value of L using the equation involving omega, Lo, and h, specifically with given values of omega = -2.6, Lo = 16, and h = 1.5. The subject area includes logarithmic functions and algebraic manipulation.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss the algebraic manipulation of the equation to isolate L. There are attempts to clarify the correct notation for the natural logarithm and suggestions on the order of substituting constants to avoid round-off errors.
Some participants have provided guidance on notation and algebraic steps, while others have reiterated the importance of proper abbreviation. Multiple interpretations of the algebraic process are being explored, but there is no explicit consensus on a single method.
There is a mention of potential round-off errors when substituting constants early in the calculations, indicating a concern for accuracy in the problem-solving process.
eddievic
Find L if...
[tex]\omega=\frac{1}{h}In(\frac{L}{Lo}-1)[/tex]
Find L if omega - -2.6, Lo = 16 and h = 1.5
-2.6*1.5=In(L/16-1)
-3.9=In(L/16-1
e^-3.9=L/16-1
0.02024=L/16-1
1.02024=L/16
so L=16.32384
The correct abbreviation for the natural log is 'lower case L' and 'lower case N'. You have 'Upper case I' and 'lower case N', which is incorrect. Otherwise, your algebra appears to be correct.
Ok thanks for the help I will use the correct abbreviation in future
-2.6*1.5=In(L/16-1)
-3.9=In(L/16-1
e^-3.9=L/16-1
0.02024=L/16-1
1.02024=L/16
so L=16.32384
It's best to substitute the constants at the end of your algebraic manipulation. Doing so sooner can lead to round-off errors.
This is the way I would have done it.
$$\omega=\frac{1}{h}\ln(\frac{L}{L_0}-1)$$
$$\Rightarrow h \omega = \ln(\frac{L}{L_0}-1)$$
$$\Rightarrow e^{h \omega} = \frac{L}{L_0}-1$$
$$\Rightarrow e^{h \omega} + 1 = \frac{L}{L_0}$$
$$\Rightarrow L_0 (e^{h \omega} + 1) = L$$
Now you can replace the constants.
this makes a lot of sense thanks Mark44
  • · Replies 19 ·
  • · Replies 29 ·
  • · Replies 23 ·
