Analog signal conditioning circuit
The discussion centers on the challenges of processing biomedical signals, specifically the need to amplify and digitize sensor outputs using an Instrumentation Amplifier (IA). It highlights the issue of DC voltage present in the IA output and the necessity to suppress it while retaining low-frequency signals in the 0 to 20 Hz range. Participants suggest that removing DC offset digitally after A/D conversion is a viable approach, but caution that defining a lower frequency limit and attenuation rate is crucial to avoid losing essential signal information.
  • Instrumentation Amplifier (IA) fundamentals
  • Understanding of DC offset in signal processing
  • Low-pass, high-pass, and band-pass filter techniques
  • Digital signal processing concepts
  • Research digital high-pass filter design techniques
  • Explore calibration procedures for offset recording
  • Learn about A/D conversion methods for biomedical signals
  • Investigate the impact of filter attenuation rates on signal integrity
Biomedical engineers, signal processing specialists, and anyone involved in the design and implementation of biomedical sensor systems.
shaikss
Hi,
For any biomedical applications, the sensor output has to be amplified and digitized.
For amplification, we use Instrumentation amplifier. But the output of IA has some dc voltage. So, how to suppress the dc voltage. At the same time, all biomedical signals are low frequency signals in the order of 0 to 20Hz. Which filter technique is better to use?
Is it good to go for Low pass/High pass/Band pass filter? Can you pls throw some light on this?
Personally I would remove the dc offset digitally after a/d conversion. Depending on how the data looks you could have a digital high-pass or you could have a calibration procedure where you record the offset.
You have specified an impossible condition. If your signal has the range of 0 to 20 Hz then you can't remove the DC without removing some of the signal. You must first define a lower frequency limit and an attenuation rate before you can talk about removing the DC.
  • · Replies 24 ·
  • · Replies 29 ·
  • · Replies 47 ·
  • · Replies 28 ·
