How Is EMF Induced in a Loop Within a Solenoid?
  • Thread starter Thread starter kinof
    Emf Loop
The discussion focuses on calculating the amplitude of the electromotive force (emf) induced in a small loop placed within a solenoid. The solenoid has 854 turns per centimeter and carries a sinusoidal current with an amplitude of 1.28 A and an angular frequency of 212 rad/s. The correct induced emf is determined to be 0.198 mV, contrasting with an initial incorrect calculation of 6.29E-5 V. The discrepancy arises from the proper application of the derivative of the sinusoidal current function.
  • Understanding of electromagnetic induction principles
  • Familiarity with solenoid characteristics and formulas
  • Knowledge of sinusoidal functions and their derivatives
  • Proficiency in calculating magnetic flux and induced emf
  • Study the derivation of Faraday's Law of Electromagnetic Induction
  • Learn about the relationship between current, magnetic fields, and induced emf in solenoids
  • Explore the application of calculus in electromagnetic theory, particularly derivatives of sinusoidal functions
  • Investigate practical applications of induced emf in electrical engineering
Physics students, electrical engineers, and anyone studying electromagnetic induction and its applications in circuits.
kinof
A small loop with area 6.8 mm^2 is placed in a long solenoid with 854 turns/cm and a sinusoidally varying current w/ amplitude 1.28 A and angular frequency of 212 rad/s. What is the amplitude of the emf induced in the loop?
[itex]\textbf{B}=\mu_0 in[/itex]
[itex]\Phi_B = BA[/itex]
[itex]emf = \frac{d\Phi_B}{dt}[/itex]
Since the current is changing, the emf through the loop should be [itex]\mu_0 n A \frac{di}{dt}[/itex]
If the angular frequency is 212 rad/s, then the current changes by 1.28 A in half a period, which is [itex]\frac{\pi}{212}[/itex] seconds. So the induced emf should be 6.29E-5 V, but the answer is .198 mV.
kinof said:
1.
Does not make sense to me.
If the current is i*sin(wt), what is di/dt? The rest of what you did looks OK.
BTW I also get 0.198 mV.
