Gravity is different - infinite energy stored
The discussion centers around the nature of gravity, particularly the concept of gravity as a "bottomless" form of energy, as presented by Prof. Paul Steinhardt. Participants explore theoretical implications, comparisons with other forces, and the mathematical underpinnings of gravitational energy in the context of general relativity and cosmology.
  • One participant cites Steinhardt's claim that gravity is unique because it lacks a minimum energy state, leading to the idea of a "bottomless" potential energy curve.
  • Another participant challenges this notion, arguing that similar potential behavior exists for opposite electric charges, suggesting that the perceived uniqueness of gravity may stem from misapplication of mathematical principles.
  • A different participant notes that gravity's uniqueness may lie in its effect on light cones and its exclusion from the Standard Model, indicating a fundamental difference from other forces.
  • One participant references a theorem in general relativity stating that for asymptotically flat gravitating systems, total energy is well-defined and must be non-negative, questioning the "bottomless" claim.
  • Another participant introduces the concept of free fall in a gravitational field, emphasizing that motion in such a field is indistinguishable from being at rest in a spaceship, highlighting a unique aspect of gravitational interaction.
Participants express differing views on the nature of gravity and its comparison to other forces. There is no consensus on whether gravity's potential energy is truly "bottomless," and various interpretations of its uniqueness are presented.
Participants reference specific concepts from general relativity and quantum field theory, but the discussion includes unresolved assumptions and differing interpretations of gravitational energy and its implications.
Lapidus
Around time 33:40 min in this video, Prof. Paul Steinhardt says the following about gravity:
There is something special about gravity that we all should have learned school, but never did. It is a very basic fact, which is that all the other energies we know have a bottom to them. If you draw the energy down, you eventually hit zero or a minimum where you can't get go below it. It is not true for gravity. Gravity is a unique form of energy which is bottomless.(...) The gravity potential curve goes to negative infinity when two objects are brought arbitrarly close to one another.
This argument is often brought forward, as in this case here, when inflationary cosmology is explained. The energy of the inflating universe comes from gravity or energy of the inflating universe is conserved since the energy of the inflation field is set off by the energy of gravity.
I also know from introductory QFT courses that gravity is special. When computing the vacuum energy, it is pointed out that for gravity not the potential energy difference but the total potential energy matters.
1. But where do I find this "bottomless feature" of gravity in the gravity and GR textbooks? Which chapter or formula in, say, Sean Carroll or in Bernard Schutz book explains it?
2. What makes gravity "bottomless"? Why does the same explanation does not apply for two opposite electric charges brought arbitrarly close to one another?
thank you in advance
That is nothing special in gravity, you get the same potential for opposite electric charges. It is a mathematical artifact, however, he tries to apply a formula in a region where it is not valid. You cannot bringt two objects as close to each other as you like, and black holes have a finite energy as well.
I did not watch the video yet, but had the same reaction as was posted...
As far as I have learned, the only 'unique' thing about gravity is that it tilts light cones...
that and the related fact that it has not yet been included in the Standard Model because it stands alone from the other forces...
I'll be interested to hear what Steinhardt has to say. Thanks for the link.
edit: "When computing the vacuum energy, it is pointed out that for gravity not the potential energy difference but the total potential energy matters..."
Can anyone expand on this a bit??
Au contraire, there's a well-known theorem in GR, "For asymptotically flat gravitating systems
the total energy is well defined and must be non-negative."
gravity is different-infinite energy stored
I think there is something else also unique about gravity. Motion is a gravitational field (in the absence of other forces) is a "free fall". If you are in a opaque spaceship (cannot see ouside), you cannot tell whether you are sitting on a planet, moving with a constant velocity, orbiting a planet or a star, or moving along a complex curved path in a gravitational field. You will feel no jerks at all. This is so even when falling in a black hole, until tidal forces become appreciable (if a point mass is falling into a black hole, it will be a free fall). This is because gravitational force is proportional to inertial mass. Hence, acceleration is constant for all the parts of your body as well as the spaceship. This will not happen in any other field-force, because other forces are not proportional to inertial mass.
  • · Replies 130 ·
18K
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 31 ·
