Boat's conservation of momentum
The discussion revolves around a problem in momentum conservation involving three boats of equal mass, where loads are thrown between them. Participants are exploring how to determine the final speeds of the boats after the loads are transferred, considering the initial conditions and the relative speeds of the loads.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of conservation of momentum to find the final speeds of the boats. There are attempts to derive expressions for the speeds based on the initial momentum and the effects of the loads being thrown. Questions arise regarding the dependency of the final speeds on the variable u and the simplifications made during calculations.
The discussion is ongoing, with participants providing different approaches to solving for the speeds v1 and v3. Some participants suggest that the speeds can be found similarly to v2, while others express confusion about the elimination of the variable u in their calculations. There is no explicit consensus, but various lines of reasoning are being explored.
Participants are working under the constraints of the problem as posed, including the requirement that the final expressions for the speeds must incorporate the variable u. There is a noted complexity in the algebraic manipulation of the momentum equations that may affect the clarity of the solutions.
quark001
Three boats with the same mass P travel in line ahead (one after the other) with the same speed v. Two identical loads of mass P1 each are thrown simultaneously from the middle boat to the front and rear boats with the same speed u relative to the boat. What are the speeds of the boats (v1, v2, and v3) after the loads have been thrown across?
My attempts:
The speed of the masses relative to the ground will be v+u and v-u. Considering only the second boat and applying conservation of momentum, you get: Pv = (P - 2P1)(v2) + P1(v + u) + P1(v - u), and v2 = v. That part is fine.
Now considering all the boats in the initial, final, and intermediate stage: 3Pv = (P+P1)v1 + (P+P1)v3 + (P-2P1)v = 2Pv + (P-2P1)(v) + P(v+u) + P1(v-u). Now the expressions for v1 and v3 as given in the solutions section should not contain v1 or v3, and they must contain u. I don't understand how that's possible since if you simplify the rightmost side of the equation, u is eliminated.
I don't quite understand your reasoning. Why not just find the speeds v1 and v3 just like you found the speed v2? You'll get your answers in terms of v and u.
If you simplify 2Pv + (P-2P1)(v) + P(v+u) + P1(v-u), you get 2Pv + (P-2P1)(v) + 2Pv = 5Pv - 2P1v. I could solve for v1, but my answer was independent of u.
Sorry, but I don't understand what you're doing.
Try this. Start with boat 1. What is its total momentum after the load is dropped into it? Use that to solve for v1.
  • · Replies 27 ·
  • · Replies 16 ·
  • · Replies 30 ·
