Coefficients using orthogonality relation
The discussion focuses on deriving the coefficients \( a_n \) for the temperature solution \( u(x,t) \) of a heated rod using the orthogonality relation. The coefficients are expressed as \( a_n = \frac{2}{L} \int_{0}^{L} \cos\left(\frac{n\pi x}{L}\right) f(x) \, dx \). The participants utilized inner product relations and norms to validate their calculations, specifically addressing the cases for \( n = m \) and \( n \neq m \). The issue regarding the norm squared was clarified, leading to a resolution of the problem.
  • Understanding of Fourier series and orthogonality relations
  • Familiarity with inner product spaces
  • Knowledge of calculus, particularly integration techniques
  • Basic concepts of heat equations and boundary conditions
  • Study the derivation of Fourier coefficients in depth
  • Explore the properties of orthogonal functions in functional analysis
  • Learn about the heat equation and its solutions in various domains
  • Investigate the implications of norm calculations in inner product spaces
Mathematicians, physicists, and engineering students focusing on heat transfer, Fourier analysis, and differential equations.
FatPhysicsBoy
Have a solution for the temperature u(x,t) of a heated rod, now using the orthogonality relation below show that the coefficients [itex]a_n , n = 0,1,2,...[/itex] can be expressed as:
[tex]a_n = \frac{2}{L} \int_{0}^{L} cos\frac{n\pi x}{L} f(x) dx[/tex]
[tex]\int_{0}^{L} cos\frac{n\pi x}{L} cos\frac{m\pi x}{L} dx = \left\{\begin{matrix}<br /> L & n=m=0 \\ <br /> L\delta_{nm}/2 & otherwise <br /> \end{matrix}\right.[/tex]
[tex]u(x,t)=\frac{a_{0}}{2} + \sum_{n=1}^{inf} a_n cos(\frac{n \pi x}{L})exp[-\alpha (\frac{n\pi}{L})^2 t][/tex]
[tex]u(x,0) = f(x)[/tex]
[tex]a_n = \frac{<cos(\frac{n\pi x}{L}),f(x))>}{{\left \| cos(\frac{n\pi x}{L} \right \|}^2}[/tex]
So I've tried doing this using the relation involving inner products above, I've also tried multiplying both sides of the equation [itex]f(x) = \frac{a_{0}}{2} + \sum_{n=1}^{inf} a_n cos(\frac{n \pi x}{L})[/itex] by [itex]cos(\frac{m \pi x}{L})[/itex] and integrating from 0 to L.
So going the inner product way, I think my problem is with the value of the norm squared because a similar issue turns up the other way (even though it is essentially the same thing). I get my expression for the norm and note that there are two terms with n so n = m therefore I consider the case where n = 0 therefore n = m = 0 and I get L as my norm squared. Then I consider the case where n > 0 then n = m != 0 , I then get L/2 as my norm squared. This is what doesn't make sense to me. I can get the right answer if I just consider n = m != 0 but I get a second one which isn't the answer if I consider n = m = 0.
Thank You.
I think this issue has now been solved, thank you.
