Calculating Steam Pressure in Closed Container
The discussion revolves around calculating the volume of liquid water needed to achieve a specific steam pressure (10 psi) in a closed container at a high temperature (816°C). Participants explore various equations and concepts related to gas laws, steam properties, and the conditions of the system.
  • One participant seeks to calculate the volume of liquid water required for a specific steam pressure in a sealed container, providing initial conditions and asking for guidance.
  • Several participants emphasize the importance of showing work and using relevant equations, such as the ideal gas law (PV=nRT), to approach the problem.
  • One participant shares their calculation using the ideal gas law but raises concerns about the units used and the assumptions made regarding the number of moles of water vapor.
  • Questions are raised about whether the pressure is gauge or absolute, and whether there is air in the container, which could affect the calculations.
  • Participants discuss the need to consider the specific volume of water vapor at the given temperature and pressure, noting that steam behaves differently than an ideal gas under these conditions.
  • One participant proposes using the specific volumes of water and steam to determine the ratio needed for the calculation, while another provides specific volume values for water and steam at the relevant conditions.
  • There is a suggestion to use steam tables or equations of state to find the specific volume of water vapor at the specified temperature and pressure.
  • One participant confirms their calculations align with the ideal gas law after considering the specific volumes, but seeks validation from others.
Participants generally agree on the need to use the ideal gas law and specific volume data for accurate calculations. However, there are multiple competing views regarding the assumptions and methods to be used, particularly concerning the behavior of steam and the definitions of pressure. The discussion remains unresolved with no consensus on the final approach.
Limitations include potential inaccuracies in unit conversions, the need for absolute pressure considerations, and the assumption that steam behaves ideally, which may not hold true at high temperatures and pressures.
jackal67347
I am trying to calculate the volume of liquid water i need to place in a sealed container in order to obtain 10 psi of steam pressure in that closed container.
Here are the numbers:
Temp: 816 C
Volume of steel pipe: 154.497 ml
Final pressure: 10 psi
If I left out a required number please let me know.
If you could show how you solved it or what equation you're using that' be great.
Thanks in advance to whoever helps me out!
Welcome to PF!
Is this homework or coursework? There is another section of the forum for that. Perhaps the mentors will move it.
In any case, it is required on PF that you make an attempt to solve problems on your own and show us you work. List any equations you think may be relevant and show your best attempt at a solution.
LastOneStanding said:
Welcome to PF!
I'm working on a DIY project and I'm trying to steam some catalyst. It's not related to schoolwork.
Here is my attempt:
pv=nrt
(.6805 atm)(v)=( .05555 moles h2o)( .08206) (1089.15 K)
7.296 Liters of steam required
So from the steam table I looked at .001003217 specific volume of h2o at room temp
49.526 specific volume of steam at 800C
49526 ratio
so i need .147 ml according to this calculation
You're on the right track with the ideal gas law. I'm not going to check your unit conversions, I will assume you've done them right. Few things:
- For that numerical value, the gas constant (R) has units ##m^3 atm K^{-1} kg \cdot mol^{-1}##. These do not match the units you are using for volume and mass is your calculation.
- Your volume is known: 154.497 mL. You want gas at this volume at a certain pressure and temperature. The quantity you are solving for is ##n##, how many moles of water vapour are required. I'm not sure where you got the number you input for ##n##.
- The number of moles of water vapour is the same as the number of moles of liquid water needed to produce it (conservation of particle number). So, you will want to convert the number moles of water to the corresponding mass of the water. See here for a worked example. Then converting the mass of the water to its volume is a straightforward density calculation.
Is that going to be 10 psi gage or 10 psi absolute?
And, is there going to be air in the closed container also? What is the total pressure in the container before it is sealed?
10 psi gauge
no air in the container
Thanks for your help. I redid the calculation with your suggestions but as I continued researching I discovered steam is not an ideal gas. Is this correct?
Could I use the specific volume of room temperature water vs specific volume of steam at 816 C to determine the ratio? I could then use the ratio and compare that to ml of water. Is my thinking correct here?
You need to get the specific volume of water vapor at 816 C and 1.6805 atm absolute (the ideal gas law and other more accurate equations of state are couched in terms of absolute pressure).
This is above the critical temperature of water. But you can find the specific volume either from steam tables, thermodynamic diagrams for water, or equations of state for water (e.g., z factor). You then divide the volume of your vessel by the specific volume under these conditions. This gives you the mass of water required.
.001003217 specific volume of water at room temp
2.9662 specific volume of steam at 816C
both in m3/kg
2957.328 ratio for specific volumes
So 154.497/2957.328 = .052 ml of water
Does that sound right?
both in m3/kg
Yes. That's what I get from the ideal gas law also.
  • · Replies 55 ·
  • · Replies 32 ·
14K
  • · Replies 30 ·
