Calc d<p>/dt: Calculate Derivative of Wave Function
  • Thread starter Thread starter Cogswell
The discussion focuses on calculating the time derivative of the wave function, specifically ## \dfrac{d
}{dt} ##, using the Schrödinger equation. The solution involves integrating the wave function and applying the product rule for differentiation. Key results include the expressions for the time derivatives of the wave function and its conjugate, leading to the conclusion that ## \left< -\dfrac{\partial V}{\partial x} \right> ## represents the expected value of the force acting on the system. The discussion emphasizes the importance of integration by parts to manipulate the derivatives effectively.
  • Understanding of the Schrödinger equation and its components
  • Familiarity with quantum mechanics concepts such as wave functions and operators
  • Knowledge of calculus, particularly integration and differentiation techniques
  • Experience with complex numbers and their applications in physics
  • Study the implications of the Schrödinger equation in quantum mechanics
  • Learn about integration by parts in the context of quantum mechanics
  • Explore the concept of expected values in quantum systems
  • Investigate the role of potential energy functions in wave function behavior
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as anyone interested in the mathematical foundations of wave functions and their derivatives.
Cogswell
Calculate ## \dfrac{d <p>}{dt} ##
Answer: ## \left< -\dfrac{\partial V}{\partial x} \right> ##
Schrödinger equation: ## i \hbar \dfrac{\partial \Psi}{\partial t} = -\dfrac{\hbar ^2}{2m} \frac{\partial ^2 \Psi}{\partial x^2} + V \Psi ##
Here's what I did:
## \displaystyle \dfrac{\partial}{\partial t} \int^{\infty}_{- \infty} \Psi ^* \left( \dfrac{\hbar}{i} \dfrac{\partial}{\partial x} \right) \Psi dx ##
## \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \dfrac{\partial}{\partial t} \Psi ^* \dfrac{\partial \Psi}{\partial x} dx ##
## \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \left[ \dfrac{\partial \Psi ^*}{\partial t} \dfrac{\partial \Psi}{\partial x} + \Psi^* \dfrac{\partial}{\partial t} \dfrac{\partial \Psi}{\partial x} \right] dx ## (Differentiation by Product rule)From the Schrödinger equation we get that: ## \dfrac{\partial \Psi}{\partial t} = \dfrac{i \hbar}{2m} \dfrac{\partial ^2 \Psi}{\partial x^2} - \dfrac{i}{\hbar} V \Psi ##
And it's conjugate: ## \dfrac{\partial \Psi ^*}{\partial t} = -\dfrac{i \hbar}{2m} \dfrac{\partial ^2 \Psi^*}{\partial x^2} + \dfrac{i}{\hbar} V \Psi^* ##
Putting those into my integral I get:
## \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \left[ \left( -\dfrac{i \hbar}{2m} \frac{\partial ^2 \Psi^*}{\partial x^2} + \dfrac{i}{\hbar} V \Psi^* \right) \dfrac{\partial \Psi}{\partial x} + \Psi^* \dfrac{\partial}{\partial x} \left( \dfrac{i \hbar}{2m} \frac{\partial ^2 \Psi}{\partial x^2} - \dfrac{i}{\hbar} V \Psi \right) \right] dx ##
Expanding out everything:
## \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \left[ -\dfrac{i \hbar}{2m} \frac{\partial ^2 \Psi^*}{\partial x^2} \dfrac{\partial \Psi}{\partial x} + \dfrac{i}{\hbar} V \Psi^* \dfrac{\partial \Psi}{\partial x} + \dfrac{i \hbar}{2m} \frac{\partial ^3 \Psi}{\partial x^3} \Psi^* - \dfrac{i}{\hbar} \Psi^* \dfrac{\partial}{\partial x} (V \Psi) \right] dx ##
## \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \left[ -\dfrac{i \hbar}{2m} \frac{\partial ^2 \Psi^*}{\partial x^2} \dfrac{\partial \Psi}{\partial x} + \dfrac{i}{\hbar} V \Psi^* \dfrac{\partial \Psi}{\partial x} + \dfrac{i \hbar}{2m} \frac{\partial ^3 \Psi}{\partial x^3} \Psi^* - \dfrac{i}{\hbar} \dfrac{\partial V}{\partial x} \Psi \Psi * - \dfrac{i}{\hbar} \dfrac{\partial \Psi}{\partial x} V \Psi ^* \right] dx #### \displaystyle \dfrac{\hbar}{i} \int^{\infty}_{- \infty} \left[ \underbrace{-\dfrac{i \hbar}{2m} \frac{\partial ^2 \Psi^*}{\partial x^2} \dfrac{\partial \Psi}{\partial x}}_1 + \underbrace{\dfrac{i \hbar}{2m} \frac{\partial ^3 \Psi}{\partial x^3} \Psi^*}_2 - \underbrace{\dfrac{i}{\hbar} \dfrac{\partial V}{\partial x} \Psi \Psi *}_3 \right] dx ##
I'm stuck at this point. I'm presuming there's a way to cancel out each of the integrals? I know the last integral is the one I want but I do not know how to cancel out the first 2.
I'd have kept the operator notation for longer, vis...
\renewcommand{H}{\hat{H}} \renewcommand{p}{\hat{p}}
\renewcommand{\expn}[1]{\left \langle #1 \right \rangle}
\renewcommand{dt}[1]{\frac{d #1}{dt}}
\renewcommand{dx}[1]{\frac{d #1}{dx}}
\renewcommand{intf}[1]{\int_{-\infty}^\infty #1 \; dx}
\renewcommand{ddx}[1]{ \frac{d^2 #1}{dx^2} }## Need to show:$$\text{(1)... }\dt{}\expn{\hat{p}} = \expn{-\dx{V}}$$ (i.e. Newton's second law...)
- expand: $$\begin{array}{rl}
i\hbar \dt{}\expn{\p} & = i\hbar \dt{} \intf {\Psi^\star p\Psi} \\
&= \intf { \left ( i\hbar \dt{} \Psi^\star \right ) \hat{p} \Psi + \Psi^\star \left ( i\hbar\dt{}(\hat{p}\Psi ) \right )} \; \text{ ...(2)}
\end{array}$$ - from the Schrödinger equation: $$\text{(3)... }i\hbar\dt{} \Psi = \H\Psi\\
\text{(4)... } \dt{}\expn{\p} = \frac{1}{i\hbar}\intf{ \H \Psi^\star \p\Psi + \Psi^\star \H\p\Psi} $$... hence, need to show that $$\text{(5)... } \H \Psi^\star \p\Psi + \Psi^\star \H\p\Psi = -i\hbar\Psi^\star \dx{V} \Psi$$ - which, I think, is pretty much where you are up to ;)
(caveat: do not rely on me to get the math right - check!)
- note that $$\text{(6)... }\p\H = - i\hbar \dx{} \left ( -\frac{\hbar^2}{2m}\ddx{}+V \right )$$ ... gives you third-order differentiation in x as well as the dV/dx you need.
So how do you change the order of the operations?
If you want to continue on from where you got to, use integration by parts to move ##\frac{\partial}{\partial x}## between ##\Psi## and ##\Psi^*##.
  • · Replies 30 ·
