Is the Speed of Light Tied to the Plank Distance and Time?
The discussion revolves around the relationship between the speed of light and Planck units, specifically whether any speed, including the speed of light, must be a multiple of the ratio of Planck distance to Planck time. Participants explore theoretical implications and the significance of Planck units in the context of current physics theories.
  • Some participants suggest that the question of whether any speed must be a multiple of (Planck distance)/(Planck time) cannot be answered definitively without reference to specific theories.
  • Others argue that according to Special Relativity (SR) and General Relativity (GR), the Planck length does not hold any special significance, and thus the answer is no.
  • One participant points out that while the speed of light is defined as (Planck distance)/(Planck time), it does not imply that all speeds are integer multiples of this value.
  • Another participant notes that practical speeds, such as 100 kph, are not integer multiples of (Planck distance)/(Planck time), emphasizing the granularity of measurement.
  • Some express uncertainty about the implications of Planck scale, suggesting that it is a realm where current theories may not apply reliably and where a theory of quantum gravity is needed.
  • A participant proposes that perhaps the question could be reframed to ask if every possible speed is a rational multiple of the speed of light.
  • There is a clarification that every speed less than the speed of light cannot be an integer multiple of it, reinforcing the distinction between different speeds.
  • One participant mentions that using "Planck speed" does not provide mathematical advantages, suggesting a preference for setting c=1 for simplicity in calculations.
Participants generally do not reach a consensus, with multiple competing views on the significance of Planck units and the relationship between speed and the speed of light remaining unresolved.
Participants highlight limitations in current theories when discussing the Planck scale, indicating that existing frameworks may not adequately describe phenomena at this level.
Quinzio
My question is:
since there exists a Plank time and a Plank distance, is it true or false that any speed and the speed of light in particular must be a multiple of (Plank distance)/(Plank time) ?
Am I saying something nonsense ?
It's not nonsense, but it would be a mistake to think that there's a theory-independent answer. Questions like these can only be answered by theories, and different theories may give you different answers.
SR and GR both say no. The Planck length is just a number like any other, and has no special significance.
In non-relativistic or special relativistic QM, I would have to ask "the speed of what?" since there are no classical point particles. If you're referring to e.g. the speed associated with a momentum eigenstate, then the answer is still no.
A quantum theory of gravity might give you an answer different from no, but I still don't think it would be yes. I think it would be more complicated.
The Planck units are defined such that the speed of light is the fraction (Plank distance)/(Plank time), every object with mass has to be slower than that.
Neither of them has to be a "smallest possible unit" of space or time, our current theories are just unable to (properly) describe processes at this scale.
It is false. I often travel at 100 kph wrt the surface of the earth, and 100 kph is not an integer multiple of (Plank distance)/(Plank time).
Thank goodness Dalespam just posted...I don't understand the first two posts...
As I understand Planck scale it is where the concepts of size, distance, time, break down as quantum indeterminacy becomes overwhelming. It's a range of values where our current theories no longer are reliable...where we need a theory of quantum gravity to merge GR and QM. This doesn't mean that some new theory might not form some sort of a relation ship as is suggested, but that seems beyond our reach so far.
Dale, I agree w/ your contention that it is false, but I have a quibble about your example and I'm curious if we could come up with a better one.
Here's my problem. "100 MPH" is a measured unit that is SO gross in granularity that it doesn't make sense to say that it is not an integer multiple of Pd/Pt as you've contended since even if we could measure it to 15 decimal places, it still would be VERY gross relatively speaking and COULD in fact be an integer multiple.
Unless you want to posit "100.000MPH out to 50 decimal places" (or thereabouts) it doesn't work and I can't think of anything that does even though I still agree w/ you.
I think DaleSpam's point (as well as mfb's) was that 1 Planck length per Planck time is the speed of light, 299792458 m/s. So the OP is asking if every speed is an integer multiple of that.
Every speed less than 299792458 m/s is clearly not an integer multiple of 299792458 m/s.
Perhaps the appropriate question is whether every possible speed is a fraction (rational multiple) of c. That would essentially boil down to where distances and times are integer multiples of of Planck dist and time. I don't know enough about this but my understanding is that there is not a definite answer to this (?).
Fredrik:
Ah ha!
THAT makes it clear...
Naty1 said:
Fredrik:
Ah ha!
+1 on that. I clearly wasn't really paying attention to the RESULT of the specified calculation.
Yes, that was my point. I guess I should have mentioned that the speed in the OP is c.
Sure, you can use "planck speed" if you like, they don't provide any mathematical advantage though.
We usually just set c=1 and work in really long distances and really short times.
  • · Replies 51 ·
  • · Replies 45 ·
  • · Replies 26 ·
  • · Replies 93 ·
  • · Replies 74 ·
  • · Replies 17 ·
  • · Replies 42 ·
