Electric circuits, finding current with terminal voltage
The discussion revolves around an electric circuit problem involving the calculation of current through a resistor in a series circuit, with specific voltage and resistance values provided. Participants are exploring the implications of opposing battery voltages on the overall circuit behavior.
  • Participants are examining the calculations for total resistance and terminal voltage, questioning the impact of opposing battery voltages on current flow. There is a focus on applying Kirchhoff's voltage law and understanding how it affects the circuit analysis.
Some participants have offered guidance on the application of Kirchhoff's laws, suggesting that the voltages from the batteries should be subtracted rather than added. There is an ongoing exploration of how this affects the current through the resistors, with no explicit consensus reached yet.
Participants are working under the constraints of a homework assignment, which may limit the information they can provide or the methods they can use. There is a mention of a schematic diagram that may clarify the circuit setup, but it is not included in the discussion.
physics604
1. What current flows through the 11.0 Ω resistor?
a) 0.21 A
b) 0.27 A
c) 0.93 A
d) 1.2 A
To summarize:
V1 = 8.0 V
V2 = 5.0 V
R1 = 2.0 Ω
R2 = 11.0 Ω
R2 = 1.0 Ω
I know we shouldn't attach pictures, but the diagram does make the question a lot easier to understand.
V=IR
VT = ε-Ir
RT = 11.0 + 2.0 + 1.0 = 14.0 Ω
VT = 8.0 + 5.0 = 13.0 V
IT = V/R = 13.0/14.0 = 0.93 A.
And since current should be the same throughout a series circuit, the current through the 11.0 Ω resistor should be 0.93 too. My answer is wrong though.
Correct answer: a) 0.21 A, but I don't understand why. Please help me?
You are close but notice that the battery's oppose each other
Yes, but what affect does that have? Does it mean the current is different in different parts of the circuit?
Am I doing the VT and the RT correctly?
If you write the kirchhoff voltage law around the loop, you will find that the battery voltages will subtract rather than add as you have done.
So are you saying VT= 8.0-5.0 = 3.0 V?
But why would that happen? Kirchoff's Loops Rule just states that potential differences around a complete loop is equal to zero. Wouldn't both batteries create a positive potential change though?
Check the schematic diagram, the batteries do not add, they will subtract.
  • · Replies 20 ·
