Measuring efficiency of bioluminescent bacteria
This discussion focuses on measuring the efficiency of bioluminescent bacteria, specifically Vibrio fischeri, in converting energy to light. The proposed method involves measuring energy consumption during both dark and light states to isolate the energy used for light production. Additionally, measuring the spectral intensity of the emitted light will provide data for calculating efficiency. The use of a calorimeter is suggested for accurate measurement of energy consumed by the bacteria culture.
  • Understanding of bioluminescence in bacteria, specifically Vibrio fischeri
  • Knowledge of calorimetry techniques, particularly isothermal microcalorimetry
  • Familiarity with spectral intensity measurement methods
  • Basic principles of energy conversion and efficiency calculations
  • Research isothermal microcalorimetry techniques for measuring metabolic heat
  • Learn about spectral intensity measurement methods for quantifying light emission
  • Explore energy efficiency calculations specific to bioluminescent organisms
  • Investigate comparative studies between bioluminescent bacteria and traditional light sources like LEDs
Researchers in microbiology, environmental scientists, and anyone interested in the efficiency of bioluminescent organisms compared to conventional lighting technologies.
BritKnight
Hi,
I want to run an experiment to try and experimentally determine the efficiency (as in what percent of energy is converted to light) of bioluminescent bacteria (V. Fischeri), and compare it to the efficiency of a "traditional" light source, like an LED or an incandescent.
I know how I would determine the efficiency of an electrical source (measure the temperature of the source, turn it on, measure the temperature again after a set time, and use a couple of equations to determine energy lost as heat over energy consumed), but I am stuck on how I would measure the efficiency of a bacteria culture. The same temperature idea might work to determine the waste heat, but how would I find total energy consumed (or energy emitted as light)?
Any ideas would be appreciated!
Thanks, Charles
Biology news on Phys.org
Interesting question.
If you can measure the energy consumed by the bacteria both when they are 'dark' and when they are 'light', you know how much energy is being used to generate light (as opposed to overall metabolic expenditures). Then, if you measure the radiated power (you would need to measure the spectral intensity), you have the efficiency.
But- how to measure the energy consumed? I guess you could culture the bacteria in a calorimeter and measure the heat:
http://aem.asm.org/content/44/5/1102
http://en.wikipedia.org/wiki/Isothermal_microcalorimetry
Tricky measurement!
16K
  • · Replies 16 ·
