Register to reply
White Silica?
by mymachine
Tags: silica, white
Share this thread:
mymachine
#1
May21-13, 10:00 PM
P: 42
This is the silica gravel that I already own:
silica gravel
If I compare to the other silica form such as below silica powder:
silica powder
silica powder 2
How can the brown-color silica gravel tuned into white silica powder?
Thank you
Phys.Org News Partner Engineering news on Phys.org
Printing the metals of the future
New gadget helps the vision-impaired to read graphs
3D printing helps designers build a better brick
Simon Bridge
#2
May22-13, 12:51 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,463
It has to be processed to remove impurities.
There are lots of different kinds of silica and different forms that silicon-dioxide can take.
http://en.wikipedia.org/wiki/Silicon_dioxide
mymachine
#3
May22-13, 09:02 PM
P: 42
Quote Quote by Simon Bridge View Post
So the brown-color silica gravel and the white silica powder is different?
Or both are the same?
If same, the brown-color silica gravel is being cleaned until the color is white.
Next crush it using the stone crusher machine to get the powder?
Simon Bridge
#4
May22-13, 09:21 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,463
White Silica?
If you grind your brown silica it will probably get lighter as it reflects the light differently but basically yes: the white silica in the pic is most likely just a different kind of silica ... probably a totally different manufacturing process.
Your brown silica actually has lots of different colors in it you notice - including plain white. So you could painstakingly go through and separate out the white ones...
"Cleaning" would have to be more than just soaking in bleach or scrubbing with soapy water - it's not "dirty" as such since it is dirt. Some of the actual crystals probably have elements other than silicon and oxygen in it - giving it some extra color - and the grains will be made of different arrangements of the atoms anyway.
Register to reply
Related Discussions
Calculating the percentage of silica Biology, Chemistry & Other Homework 3
Question about silica Chemistry 2
Plucking a white hair would result in more white hairs Biology 2
Lunar silica Astronomy & Astrophysics 1
Probability question - Bayes' Theorem - 4 Balls, 2 white, P(all white) = ? Precalculus Mathematics Homework 4
