Earth-Moon Barycenter and Pro-Retrograde motions
  • Context: Graduate
  • Thread starter Thread starter Lifepsy
The discussion revolves around the Earth's motion around the Earth-Moon barycenter and whether this motion results in observable prograde and retrograde motions of celestial bodies, particularly the Sun and other planets. Participants explore the implications of this motion for both naked-eye observations and scientific measurements, delving into concepts such as parallax and the significance of the observed effects.
  • One participant questions why we do not observe noticeable prograde and retrograde motions of celestial bodies due to the Earth's orbit around the Earth-Moon barycenter.
  • Another participant provides a parallax calculation suggesting that the maximum observable "wobble" is approximately 2 arcminutes, which is difficult to detect without precise instruments.
  • A participant seeks clarification on whether empirical observations confirm the existence of pro-retrograde motions due to the Earth's wobble around the barycenter.
  • One participant corrects their earlier calculation, stating that the observable wobble is actually 29 arcseconds, and notes that while the wobble exists, it is not significant enough to be widely discussed.
  • Another participant mentions that detailed planetary ephemerides can reveal the wobble, but emphasizes that the effect diminishes with distance from the Earth-Moon barycenter.
Participants generally agree that the wobble exists but express uncertainty about its significance and detectability. There is no consensus on the extent to which this wobble is observed or discussed in current literature.
Participants note limitations in their calculations and the need for precise measurements to confirm the effects discussed. The small scale of the Earth's motion around the barycenter and its impact on observations is highlighted as a factor in the discussion.
This discussion may be of interest to those studying celestial mechanics, observational astronomy, or anyone curious about the effects of the Earth-Moon barycenter on celestial observations.
Lifepsy
Hello, this is my first post.
My question is, if the Earth is revolving around the Earth-Moon barycenter as it orbits the sun, then why don't we observe a slight respective prograde and retrograde motion of other celestial bodies?
In other words, if the Earth is moving 'forward' on the orbit of the Earth-Moon barycenter, and then 'backward' on that same orbit, why don't we observe a slight stuttering motion of the Sun and other celestial bodies, due to that pro-retrograde motion of the Earth?
Or do we observe this??
I've been searching around for a few days and have been unable to find any discussion of this issue.
Thanks
Astronomy news on Phys.org
Hello, Lifepsy.
When you say "we" I assume you mean naked-eye observers, and not accurate scientific measurements(which, of course, have to account for it).
Having done quick parallax calculations, I've found the maximum observable "wobble" to amount to approximately 2 arcminutes, or 1/15th of the Solar disc's diametre, spread over half a lunar month.
Twice that amount for Mars at it's cloest approach(~0,5AU).
2 arcminutes is the amount the Sun travels in in the sky in 8 seconds. See if you can spot such a small difference. Now consider that you've got ~14 days of gradual change to cover the same angular distance.
Try calculating it yourself. Use the skinny triangle approximation to get the angle in radians:
http://en.wikipedia.org/wiki/Skinny_triangle
Note that the base of the triangle used to calculate the above parallax is ~ 21 000 km, which is not even twice the Earth's diametre, which in turn can be used to calculate daily parallax(the amount of wobble between morning and evening due to Earth's rotation). This means that you get more than half of the same wobble by comparing the raising and the setting Sun, but spread over 12 hours instead of half a month.
Thanks for the reply, Bandersnatch
I guess by "we", I meant either the naked-eye or any measurements observed by instrumentation.
I see you have a parallax calculation for measuring the wobble which I will try and work out for myself... Does this mean the pro-retrograde motions of celestial bodies due to Earth's wobble around Earth-Moon barycenter are, in fact, empirically observed?
And measuring devices do confirm the Sun,etc. demonstrate slight pro-retrograde motions every period of Earth's revolution around Earth-Moon barycenter?
I am trying to confirm this, as I've never heard it mentioned before and can't find any official statements.
I've made a couple of errors in my calculations(:blushing:). That should be 29 arcseconds, not 2 arcminutes(i.e., 4 times less).
The wobble is there, but it's not a very useful, significant, or interesting thing by itself. That's why you don't hear much about it.
You can find some(not a whole lot) information about it by googling "barycentric parallax".
For example, there's this article from 1924:
http://adsabs.harvard.edu/full/1924LicOB..11..187L
That mentions they had to correct for the effect.
You might find some mention in discussions of systematic observational errors too.
Thanks for the link, Bandersnatch, though I don't think I'm able to interpret the results. I see this is from 1924, I was hoping there would be some current documentation with more precise measurements available.
I will look around more with those keywords, 'barycentric parallax'
Thank you.
The wobble you're looking for exists. You won't find it except in very detailed planetary "ephemerides", which are just descriptions of the motions of the planets. Don't forget, the motion of the Earth around the E-M barycenter is small, and the farther away the planet is, the less parallax it will have due to that small motion. It's similar to the "diurnal parallax" caused by being on opposite sides of the Earth - this makes some difference in the observed position of the Moon, much less for any of the planets.
  • · Replies 41 ·
  • · Replies 83 ·
  • · Replies 51 ·
  • · Replies 24 ·
