Calculating Energy of Two Masses on a Spring
  • Thread starter Thread starter bessletama
    Mass Spring
The discussion focuses on calculating the energy of a macroscopic oscillator consisting of two equal masses attached to a spring, oscillating with amplitude A at frequency v. The user assumes a frictionless environment and derives the position and velocity equations using classical physics principles. The maximum velocity is determined, leading to an energy calculation of the spring. However, feedback suggests that the user should consider the relative motion of both masses and utilize a free body diagram to solve the differential equations governing their motion.
  • Understanding of classical mechanics principles, specifically oscillatory motion.
  • Familiarity with harmonic oscillators and their energy equations.
  • Knowledge of differential equations and free body diagrams.
  • Ability to apply trigonometric functions in physical contexts.
  • Study the principles of harmonic oscillators in classical mechanics.
  • Learn how to derive energy equations for systems with multiple masses on springs.
  • Explore the use of free body diagrams to analyze forces in oscillatory systems.
  • Research differential equations related to coupled oscillators and their solutions.
Students studying classical mechanics, physics educators, and anyone interested in understanding the dynamics of oscillatory systems involving multiple masses and springs.
bessletama
Consider the following macroscopic oscillator: Two masses of equal mass are attached to a spring and oscillate with amplitude A at frequency v. Use classical physics to calculate the energy of the oscillator.
This question doesn't say much about where the mass is attached or what environment this oscillator is in so I assumed that we're in a friction-less environment and the mass is attached on either end of the spring. Please tell me if that is incorrect.
Based on that assumption, I know that the position of one of the mass would travel in a cosine curve. So we have p(t)=A*cos(2*pi*v*x). I can take the derivative of this to get the velocity v(t)=-2*pi*A*v*sin(2*pi*v*x). The maximum velocity is when t=1/(4v). Let's call this new velocity V. Now the energy of the spring should be 2*((1/2)*m*V^2). Is this correct? Or is there another way to do it.
Thanks in advance!
You should verify the assumption ... but it is what I'd do.
What you seem to have done is considered the motion of just one mass, assuming the other one is stationary.
The force on the masses depends on their relative positions - so you'd work out the free body diagram and solve the resulting differential equation.
If their motion is antisymmetric with the same amplitude, then you can simplify the problem quite a lot.
  • · Replies 31 ·
