Proof Help: If a and b are Real Numbers, a^2 + b^2 ≥ 2ab
  • Context: Undergrad
  • Thread starter Thread starter woundedtiger4
    Proof
The discussion revolves around the proof of the inequality \( a^2 + b^2 \geq 2ab \) for real numbers \( a \) and \( b \). Participants explore various approaches to proving this inequality, including the use of squares and conditions on the values of \( a \) and \( b \). The conversation includes technical reasoning and challenges to the assumptions made in the proofs presented.
  • Some participants propose using \( (a-b)^2 \) as a basis for the proof, arguing it leads to the correct conclusion that \( a^2 + b^2 \geq 2ab \).
  • Others challenge the assumption that \( a \) and \( b \) must be non-negative, stating that the proof should hold for all real numbers.
  • A participant suggests that if \( a \) and \( b \) are equal, the original proof remains valid, questioning the necessity of certain conditions.
  • There is a discussion about the implications of using \( (a+b)^2 \) versus \( (a-b)^2 \) in the proof, with some arguing that the former leads to incorrect conclusions.
  • One participant expresses confusion about how \( (a+b)^2 \geq 0 \) relates to the inequality, seeking clarification on the proof structure.
  • Another participant emphasizes that the proof must not rely on conditions that limit \( a \) and \( b \) to non-negative values, as the goal is to prove the inequality for all real numbers.
Participants do not reach a consensus on the proof method or the assumptions regarding the values of \( a \) and \( b \). There are competing views on the necessity of conditions and the validity of different proof approaches.
Some participants highlight the limitations of assuming \( a \) and \( b \) are non-negative, which restricts the generality of the proof. There is also uncertainty regarding the implications of using different algebraic forms in the proof.
woundedtiger4
If a and b are real numbers, then a^2 + b^2 >= 2 a b
Proof:
if a>=0 and b>=0
then a-b>=0
(a-b)^2>=0
a^2 + b^2 -2ab >=0
a^2 + b^2 >= 2ab
Q.E.D.
at http://answers.yahoo.com/question/index?qid=20081104233240AApFu9W
someone has proved more or less similar question, but at
(a + b)^2 > 0
a^2 + 2ab + b^2 > 0
a^2 + b^2 ≥ 2ab
when 2ab goes from L.H.S. to R.H.S then it should be -2ab , am I correct?
Yes, and that's why you should use ##(a-b)^2## instead of ##(a+b)^2## to prove this result.
You should remove the first two lines from the first proof. Do you see why?
Because a and b could be equal, right?
If I am correct then it should be:
Proof:
If a-b>=0
then (a-b)^2 >= 0
a^2 + b^2 - 2ab >= 0
implies a^2 + b^2 >= 2ab
Q.E.D.
But if a and b could be equal to each other then ">=" justifies that so the proof in my original post remains correct, isn't?
Proof:
if a>=0 and b>=0
then a-b>=0
This is not true. Given that a and b are arbitrary real numbers, a- b can be any number, positive, negative, or 0.
However, since a square of a real number is never negative, the next step is correct:
(a-b)^2>=0
a^2 + b^2 -2ab >=0
a^2 + b^2 >= 2ab
Q.E.D.
(a + b)^2 > 0
If a and b are not allowed to be equal, yes. otherwise (a+ b)^2>= 0 as you had before.
a^2 + 2ab + b^2 > 0
a^2 + b^2 ≥ 2ab
Yes, but since a and b can be any real numbers, either 2ab< 0, in which case, since a^2+ b^2 is not negative, it is a trivial statement, or 2ab> 0 so that the sign doesn't matter.
HallsofIvy said:
This is not true.
Ahaan i see your point.
Proof:
If a-b >=0
then (a-b)^2 >=0
a^2 +b^2 -2ab >=0
a^2 + b^2 >=2ab
Q.E.D.
What do you say?
Proof:
If a-b >=0
then (a-b)^2 >=0
a^2 +b^2 -2ab >=0
a^2 + b^2 >=2ab
Q.E.D.
What do you say?
You seem to be stuck on this idea of a-b ≥ 0 that is completely unnecessary. Compare your proof to the following:
If the sky is blue
then (a-b)^2 >=0
a^2 +b^2 -2ab >=0
a^2 + b^2 >=2ab
If the sky is blue
then (a-b)^2 >=0
a^2 +b^2 -2ab >=0
a^2 + b^2 >=2ab
Ohh got it. It says "a and b are real numbers".
Proof:
If (a-b)^2 >=0
then a^2 + b^2 >=0
Q.E.D.
Right?
No, the problem is that if the proof relies on the assumption that ##a,b\geq 0##, then the result will only be valid for such values of ##a## and ##b##
Don't forget that the statement you want to prove is that "For all real numbers ##a## and ##b##, we have ##a^2+b^2\geq 2ab##. It's for all real numbers, not just for the non-negative ones.
Proof:
If (a-b)^2 >=0
then a^2 + b^2 >=0
Q.E.D.
Right?
What makes you think that ##(a-b)^2## may be less than 0, or that it needs to be greater than or equal to zero to ensure that ##a^2+b^2\geq 0##?
Proof:
If a,b>=0
then (a-b)^2 >=0
a^2 +b^2 -2ab >= 0
a^2 + b^2 >= 2ab
QED
I don't understand that how come (a+b)^2 >=0 can lead us to prove that a^2 + b^2 >= 2ab because (a+b)^2 >= 0 will lead us to the resut a^2 +b^2 >= -2ab , please explain to me in a simple language becaueee I am a beginner.
PS. I want to prove this thm by using direct proof's if & then technique.
Thanks in advance.
Can you give me some real numbers such that ##(a-b)^2<0##?
I didn't express myself very clearly here. I meant that if you assume that ##a,b\geq 0## and then find that ##a^2+b^2\geq 2ab##, you will only have proved that ##a^2+b^2\geq 2ab## for all non-negative real numbers ##a## and ##b##.
But your goal was to prove that ##a^2+b^2\geq 2ab## for all real numbers ##a## and ##b##.
  • · Replies 18 ·
  • · Replies 39 ·
13K
10K
