Events in Relativity: Can Simultaneous Occurrences Exist?
  • Context: Graduate
  • Thread starter Thread starter Salman2
    Events Relativity
The discussion revolves around the concept of 'events' in relativity theory, specifically whether an event can occur simultaneously at two different spatial locations. Participants explore the implications of simultaneity in different frames of reference and consider how the definition of an event might affect the understanding of relativity.
  • Some participants assert that an event is defined as a single point in spacetime, implying it cannot occur at two different spatial locations simultaneously.
  • Others argue that simultaneity is frame-dependent, suggesting that two events can be perceived as simultaneous in a specific frame of reference.
  • A participant questions whether a quantum of energy in the double-slit experiment could be considered a single event occurring at two locations.
  • Some propose hypothetical modifications to the definition of an event, suggesting that if events could be defined as simultaneous occurrences at two locations, it would not fundamentally alter the mathematical framework of relativity.
  • One participant mentions a theory with multiple time dimensions that could explain phenomena like the double-slit experiment, although they note it is considered "intolerably weird."
  • Another participant emphasizes that redefining the term "event" does not change the mathematical treatment of events in relativity.
  • Concerns are raised about the lack of a universally agreed-upon definition of simultaneity when considering events at different spatial locations.
Participants express differing views on the definition of an event and its implications for relativity. There is no consensus on whether events can be simultaneous at different locations, and the discussion remains unresolved.
Participants highlight the dependence of simultaneity on the observer's frame of reference and the implications this has for defining events. The discussion also touches on the complexities of quantum mechanics and how they relate to classical definitions of events.
This discussion may be of interest to those studying relativity, quantum mechanics, or the philosophical implications of simultaneity in physics.
Salman2
I have a question about the concept of an 'event' in relativity theory.
Can an 'event' occur simultaneously at two spatial locations, A & B where (A=x1,y1,z1, B=x2,y2,z2), AT THE SAME MOMENT IN TIME ? For example, suppose two observers at locations A and B not far separated. Can they both experience the same 'event' at the same moment in time ?
No. The definition of an event is a single point in spacetime--that means a single spatial location at a single instant of time.
Note that simultaneity is frame dependent, it has no absolute meaning. So to continue, we must pick some frame ##O## and talk about simultaneous events with respect to ##O##. Given that, certainly two events can have different spatial locations but the same time as represented in ##O## - for example the observer associated with ##O## might see two bombs go off at the same time but at two different locations in space. However, it makes no sense to say a single event can have two different spatial locations as represented in ##O## because the event gets a unique coordinate representation in ##O##.
WannabeNewton said:
.. it makes no sense to say a single event can have two different spatial locations as represented in ##O##
Thanks for the comment, but, does not a quantum of energy as a wave enter the two different spatial locations of the two slits in the double-slit experiment as a single event ?
Edit: Suppose we assume the two slits are in the frame of reference O of the quantum wave, and not from the frame of the structure into which the slits are cut from.
OK thanks.
But, just asking...how would relativity theory be modified if an event was defined as: an event is defined as a phenomenon that occurs simultaneously at two spatial locations, A & B where (A=x1,y1,z1, B=x2,y2,z2), AT THE SAME MOMENT IN TIME ?
Salman2 said:
OK thanks.
Add another time dimension. There was a theory proposed once that had 3 timelike and 3 spacelike dimensions and it explains the double-slit very well. But it is otherwise intolerably weird.
I am not sure about how events work in quantum theory but the notion of an event, as represented in an observer's frame, only makes sense when the observer actually makes a measurement of the position and time of the event. For the double-slit experiment, a measurement of position would cause the state vector to take on a definite eigenstate of the position operator although I don't know if this has the same meaning as making a measurement in special relativity so don't take my word for it.
No. There are two separate events, each of which has an amplitude associated with it. (At least, that's true if "event" is defined in the standard way. See my next post for a comment about that.)
I don't see how this modifies the theory of relativity; it just modifies the definition of an English word, "event". Relativity as a theory is not done in English; it is done in math. Redefining the word "event" doesn't change the math at all. In the math, you still have two spatial locations at some instant of time.
Salman2 said:
OK thanks.
Google around for Einstein's thought experiment involving the train and the relativity of simultaneity (hereis one reasonable-looking link high in Google's page rank).
If you think through that example you'll see that there's no way of defining an event, or anything else for that matter, in terms of things that happen at the same moment in time but at different spatial locations. There cannot be any generally agreed-upon definition of "at the same moment of time".
Thanks. Do you have a reference for a publication on this theory ?
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 38 ·
