Fortran 77 compatibility with Fortran 95
  • Context: Fortran
  • Thread starter Thread starter ngendler
    Fortran
The discussion revolves around the compatibility of Fortran 77 code with a Fortran 95 program, specifically addressing issues related to including an F77 file in an F95 context and the resulting compilation errors.
  • Homework-related
  • One participant seeks help with including a Fortran 77 file in a Fortran 95 program and encounters an error indicating the file cannot be opened.
  • Another participant suggests checking the file's existence and its directory location, as well as using the full path in the INCLUDE directive.
  • A participant notes that despite resolving the initial error, the compiler generates multiple syntax errors related to the Fortran 77 code, indicating a potential compatibility issue.
  • There is a discussion about the nature of the INCLUDE statement and how it integrates F77 code into the F95 program, with one participant explaining the differences in formatting between the two versions.
  • A suggestion is made to compile the F77 code separately and link the object file to avoid syntax issues arising from the formatting differences.
  • Another participant clarifies that the default output executable name is 'a.out' and provides guidance on how to specify a different name for the executable.
Participants generally agree on the need to handle the differences in formatting between Fortran 77 and Fortran 95, but there are varying opinions on the best approach to include and compile the older code. The discussion remains unresolved regarding the specific compatibility issues encountered.
There are limitations regarding the assumptions about the compiler's behavior with different file formats and the specific error messages generated during compilation, which have not been fully explored or resolved.
Individuals working with legacy Fortran code, particularly those transitioning from Fortran 77 to Fortran 95, as well as those encountering similar compilation issues in mixed-version environments.
ngendler
Hi, I have a program written in Fortran 77 that I need to include in my Fortran 95 program. I don't have an F77 compiler, but I was told that F95 should be able to read F77 programs. I'd like to write
INCLUDE 'vegas.f'
in the first line of my program, but it's not compiling. I keep getting an error that says 'Error: Can't open included file 'vegas.f' '
Need help!
Technology news on Phys.org
You will have to do a little detective work.
Is 'vegas.f' on your computer?
Is 'vegas.f' in the same directory as the source file you are trying to compile?
Have you tried compiling your program with the full path of 'vegas.f' added to the INCLUDE directive?
It is in the same directory. I'm not sure what you mean by "full path of vegas.f"
Now I am not getting the same error message, but the compiler is simply not reading the f77 code. Over 25 errors on 'vegas.f', all about syntax that is clearly from the earlier version.
Well, we really can't provide any more detailed suggestions unless you furnish your Fortran code and the error messages. If the compiler isn't reading 'vegas.f', how are you getting specific syntax errors generated by your compiler.
Fortran 77 is supposed to be a subset of Fortran 95, in order to provide compatibility with older code.
Full path means instead of just 'vegas.f' you supply something like 'c:\subdirectory\subdirectory\vegas.f' so that the compiler can trace the location of 'vegas.f' from the root volume to the directory where the file is stored.
This is my Fortran 95 code. 'vegas.f' is written in Fortran 77 and too long to include in this reply:
INCLUDE 'vegas.f'
program vegastest
implicit none
external gaussian
call vegas(gaussian,0.d0,2,1000,5,1,0)
print *,'The integral of the gaussian is',s1
end program vegastest
When I compile it, I get over 25 errors similar to this one:
Included at vegastest.f95:1:
C*************************************************************
Error: Unclassifiable statement at (1)
This makes me think that my compiler is simply not understanding the Fortran 77 code.
The include statement just puts the contents of the file vegas.f inside the file vegastest.f95 when compiling. As the latter is in free form, while the fortran 77 file is formatted (comment indicated by C in the first column, 1st-5th columns for labels, 6th column for continuation of the previous line, statements in columns 7-80), it is normal that the compiler complains.
You shouldn't include the code, but compile it separately and link the object file. For example:
gfortran -c vegas.f
gfortran vegastest.f95 vegas.o
Most modern compilers usually assume by default that a file with extension .f is column-formatted, but some compilers can require a flag be set to explicitely indicate that a file is formatted.
DrClaude, thank you so much for helping! That worked! The only thing is that now when I try to run the program (./vegastest), it says "-bash: ./vegastest: No such file or directory". Is there a different way I have to run the program?
By default, the executable is named a.out. If you want it to be named vegastest, try
gfortran -o vegastest vegastest.f95 vegas.o
  • · Replies 25 ·
  • · Replies 17 ·
