Potassium increase or decrease with metabolic acidosis, confused?
In metabolic acidosis, renal compensation involves an increase in aldosterone, leading to the excretion of hydrogen and potassium, which can result in hypokalemia. However, transcellular movement of potassium can cause hyperkalemia initially. The final potassium level is influenced by the body's compensatory mechanisms, including respiratory adjustments to maintain acid-base neutrality. Ultimately, while hyperkalemia may occur transiently, the kidneys regulate potassium levels to achieve normal serum potassium as pH normalizes.
  • Understanding of metabolic acidosis and its physiological implications
  • Knowledge of renal compensation mechanisms, specifically aldosterone's role
  • Familiarity with acid-base balance and pH regulation
  • Basic concepts of electrolyte movement across cell membranes
  • Research the role of aldosterone in electrolyte balance during metabolic acidosis
  • Study the mechanisms of transcellular potassium movement in acidosis
  • Learn about respiratory compensation techniques for acid-base disorders
  • Investigate the clinical management of metabolic acidosis and its underlying causes
Medical professionals, particularly those in nephrology and critical care, as well as students studying physiology and pathophysiology of acid-base disorders.
sameeralord
Ok in metabolic acidosis, renal compensation is increase in aldosertone, which cause hydrogen and potassium excretion leading to hypokalemia. But in metabolic acidosis transcellular movement occurs and there is hyperkalemia. What is the final result for potassium level. Hyper or hypo?
Biology news on Phys.org
Which one do you think? You just said "renal compensation" which is relatively slow. The final result, or at least the desired result, is physiologic acid-base neutrality (pH 7.35-7.45) and normal serum potassium levels.
Since you haven't responded, I can only assume you've posted a question, but are not interested in entering into a discussion of the issues involved in arriving at an answer. Others might be interested so I'll elaborate.
In primary metabolic acidosis, the initial response is the movement of H+ ions into cells in exchange for K+ ions, as you said. This can lead to hyperkalemia but it does not affect total body potassium. The main compensatory response for metabolic acidosis is usually respiratory; accomplished by a degree of hyperventilation to expel CO2. This shifts the reaction:CO2+H2O <-> H2CO3 to the left thus decreasing carbonic acid levels and producing a secondary respiratory alkalosis. This will usually compensate for the primary acidosis up to about pH 7.2. As the pH normalizes, K+ returns to the cells in exchange for H+ (actually hydronium ions). The kidneys accomplish the final adjustment of pH, but would not be expected to over-compensate.
This this is the "stop-gap" mechanism. The cause of the acidosis needs to be addressed.
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 21 ·
