Running switching regulators in parallel
  • Thread starter Thread starter memoguy
    Parallel Running
The discussion revolves around the challenges of powering a radio for a high altitude balloon project using switching regulators. Participants explore the feasibility of running these regulators in parallel, the specifications needed for the power supply, and the implications of using different types of regulators.
  • Homework-related
  • One participant expresses uncertainty about paralleling switching regulators, noting conflicting advice on the necessity of oring diodes.
  • Another participant suggests that a single regulator rated for 2A could suffice for the radio's peak current draw, recommending ground testing.
  • Concerns are raised about the reliability and robustness of various components, particularly regarding their current ratings and the need for thorough testing before flight.
  • Participants discuss the importance of minimizing weight for the high altitude balloon project, which complicates the selection of components.
  • One participant mentions the potential need for a linear regulator to avoid issues with radio sensitivity when using switching power supplies.
  • There are suggestions to consider the duty cycle of the radio's transmission and the possibility of adding bulk capacitance to support current demands.
  • Some participants share experiences with using diodes to help balance load when paralleling regulators, while others caution about noise issues affecting radio performance.
Participants do not reach a consensus on the best approach to power the radio. There are multiple competing views on whether to parallel regulators, the necessity of linear regulation, and the implications of using switching regulators for radio applications.
Participants note limitations regarding the availability of suitable components, budget constraints, and the need for reliability in the high altitude environment. There are also unresolved questions about the specific voltage and current requirements for the radio.
memoguy
For a high altitude balloon I need to power a radio that draws 1A but briefly peaks at 1.4A for a fraction of a second. <SEE EDIT>
I was thinking of using two of these in parallel:
http://australia.rs-online.com/web/p/switching-regulators/6727133/
Or one of the above item and one of these in parallel:
http://australia.rs-online.com/web/p/switching-regulators/6727089/
But I am not sure if you can run these types of regulators in parallel. Some places have said you can, others have said you need to use oring diodes, so I am not sure what to do.
This is for a High Altitude Balloon, so this does need to be reliable.
Thoughts?
EDIT
Ok, I am an idiot. I made incorrect measurements. The peak draw is actually ~1.3A to ~1.5 continuous. (I.E. not for a fraction of a second, for all the time I am keying the radio)
As for paralleling those regulators, why not ask the manufacturer if it can be done?
The R-78B6.5-1.0 data sheet shows output overcurrent set to 2A (with automatic recovery). The performance graphs show typical output ripple voltages at output currents up to 1.2A. Accordingly, it seems one device would power your radio, even if it draws 1.4A for a fraction of a second. You could first try it on the ground easily.
I am very sorry about that mistake.
So it looks like I will have to ask the manufacturer.
Thanks for your response.
If anyone already knows about paralleling these regs please post - it may take a while for the manufacturer to get back to me.
OK. Why can you not find one regulator that outputs say, 2 Amps?
You have not told us your input voltage or your output voltage. Those would be useful to us who are trying to analyze your design. Thank you.
That is another option. The problem is that I need a black box solution (no external parts), that I can get access to easily & cheaply in Australia.
I could say buy this from digikey, but it is almost $40 shipping:
http://www.digikey.com.au/product-detail/en/R-78B6.5-1.5/945-1719-5-ND/2303077
From RS I can get free shipping but they only stock the 1A model.
This is a student project & we are on a very tight budget as you can imagine :)
That Digi-key 945-1719-5-ND is only rated at 1.5 Amps (maximum). That does not seem to be a "robust" choice. Sorry your have such a limited budget, but you need reliability, as you mentioned. You need a system that you purchase, assemble, and test thoroughly on the ground before you fly it.
I am sorry - I totally agree. I do want to choose the best option, and if that means paying a substantial amount for it I will. I just find it a bit hard to justify $40 shipping for a single component :)
Ok, so that component doesn't seem to be a good match anyway. Looks like I need a 2A reg at 6.5V to be safe.
Our input voltage is 10-13.3V
I will keep searching, if anyone has any recommendations they would be welcome :)
Many manufacturers specify their DC to DC converters by their power output. Seems you need (6.5V X 2A = ~15W)
Using Google search for 15 Watt DC to DC converters I found several. Here’s one that may work for your project: PST-DC292 Cost US$ 18.95
http://www.powerstream.com/dc6.htm
That could work but it is super heavy . This is a high altitude balloon project so weight needs to be low as possible :)
the way I read their datasheet there's a minimum 10 ma load.
Can you stand one diode drop or do you need precisely 6.5 volts?
A 10 ma LED at each output would assure minimum load, then diodes to the radio would let you parallel them - and give you an "on" light for each.
They make a 1.5 amp medical version, 6.5 would be a special. Might inquire if they've made that one for somebody already.
IN addition to the Vin / V out -- what do you expect the duty cycle to be. i.e. How long ON ( 1.3-1.5 A) and how long off?
What is the Voltage Supply range allowed by the radio?
Also - when keying ON the radio will you see a surge? If you are close to the specs for one converter - perhaps adding some bulk capacitance to the output will help.
Re Jim:
Thanks for your response. Ok, I have read about using oring diodes to run switching regulators in parallel. Have you had success with doing this?
In relation to the medical grade 1.5A version. I have seen it, however I do not have a easy way to acquire it, the shipping from digikey is $45. So If I can make the 1A version work running in parallel then that would be considerably more cost efficient.
Re Windadct:
V in - ~13V down to 10V
V out - 6.5V
Current when listening - ~100ma
Current when transmitting - ~1.5A
The radio will transmit once per minute for ~8 seconds MAX each time (probably more like 5 seconds, but 8 to be safe)
I don't think the radio surges. I think I made a bad reading as RF was getting into the multimeter wires.
I just caught up in this thread. One *very* important tip when working with radios is to NOT use a switching power supply to power them directly. You need to put a linear regulator between the DC-DC converter and your radio receiver circuitry, or you will de-sensitize the RX circuitry significantly.
It looks like it can still work, but you may want to use a SEPIC topology DC-DC conterter, so the output voltage can be held at a steady 12V, even after the battery starts to droop. That would let you use a standard-dropout linear regulator for your 6.5V radio supply voltage. Alternately, if you could get a standard DC-DC buck converter to provide you with a steady 7.5V, then you could use a low-dropout (LDO) linear voltage regulator.
The layout of your PCBA (PC board assembly) and/or wiring of the modules also needs to be done correctly, to keep digital circuit noise from getting into the RX radio circuitry. It took us a while to learn all of the tricks here where I work. If you could post what your assembly and wiring will look like, we could try to give you some tips...
I've done it before but not with this particular device. It was a different DC-DC converter with isolation.
The LED indicator meets minimum load for you.
The regulator that's set highest will hog the load until resistance of the diodes let's them share.
Thought I had a solution for you with this regulator:
http://www.ti.com/lit/ds/symlink/78sr174.pdf
but can't find a place for you to buy them.
Original National datasheet showed how to make LM317 into a 3 amp switcher.
http://www.hep.upenn.edu/SNO/daq/parts/lm317.pdf page 10 of 20
also
http://e2e.ti.com/support/power_management/linear_regulators/f/321/t/141861.aspx
But I realize you want a 'drop in' part.
Sorry , but I don't have a better answer than diodes to make them share load..
I though about plain old linear LM317 but it wastes quite a bit of power during transmit period..
Try a bench check using the diodes with 10 ma LED to keep each supply happy about minimum load. I think it's a reasonable and practical solution.
Beware of noise. Like Berkeman I have chased switcher noise all over analog circuits. I have not much radio experience and am sure glad he rang in .
old jim
Is this only an issue on RX? As we are not really using RX, only TX.
Thanks for your tips, if this is going to be an issue of TX then we will have to go for the linear solution you suggest.
It is mainly an RX issue. The desensitization of the RX stage can be on the order of 30-40dB, which makes the receiver close to useless. If you will only use the RX up close (like before you launch the balloon), then it will probably work.
Another thread came up with this little switcher
looks right flavor, 3 amps, has two more pins for output adjustment..
see if they're available in your neck of the woods ?
http://www.tracopower.com/fileadmin/medien/dokumente/pdf/datasheets/tsr3.pdf
Here's the distributor "Down Under" :
http://www.kdfisher.com.au/
Ok. I am thinking I will use the LED, diode, switching solution Jim suggested. I can just use a small receiver on a linear regulator for RX.
Ok, so I am thinking of getting this:
http://australia.rs-online.com/web/p/switching-regulators/6664372/
http://australia.rs-online.com/web/p/rectifier-schottky-diodes/7010209/
I am just not sure what kind of LED to use or how to wire it, do I need to use a resistor? Also, I think that it would be good if I could find a diode with a lower voltage drop, but I can't see any on RS.
The diode you linked is a Schottky, and low forward voltage drop is characteristic of Schottkys. It looks like a fine choice.
Most any LED will do.
Here's one that your supplier says he can deliver in ten days with no shipping charge:
http://australia.rs-online.com/web/p/pcb-led-indicators/2508413892/
Looks like they come 100 to a pack so you'll get a lifetime supply.
or two in one package
http://australia.rs-online.com/web/p/pcb-led-indicators/2509027767/
It'll need a resistor to set current
to size resistor for ten milliamps
subtract from your 6.5 volts the forward drop across LED;
6.5 - ~2.4. = 4.1
That's voltage across resistor
R = E/I , I = .01 amp so you want ~ 410 ohms
you might aim at 12 ma to leave tolerance ,~ 341 ohms
360 and 390 are standard values .
That current rating on LED's is for full intensity. They'll be quite visible at lower current.
Were his catalog easier to search i'd have looked for 10ma LED's with built-in resistors.
a 12volt 25 ma might draw about 10ma at 6.5 volts, if avoiding the resistor is worth an experiment
Good luck !
old jim
Quite a robust part, that, and thanks for the link. I need a few for an old flatscreen TV I'm trying to resuscitate. Will find 'em here, though.
If you are planning to use two regulators in parallel, you will need them to be very well matched (they are 'voltage sources' and one will almost certainly be 'doing all the work') or you would need some finite series resistance in each circuit to allow for voltage discrepancies (in addition to the protection diodes). Either way, you can't assume an equal sharing of the current supplied - so that implies a need for two beefier regulators and a lot more than half current capability (or even 0.7) for each.
Would it really be too hard to design and build a special, linear regulator? I appreciate the need for energy efficiency in your balloon system.
Well I have already bought the parts, so I will just make it and see how the distribution is.
That will be interesting. Let me know if my 'balance' concern turns out to be valid. I know that batteries in parallel will give such problems unless they are of identical types, age and state of charge. Be sure to use two identical meters at the same time when measuring the current. The meter resistance will / could be relevant.
Well this is sure interesting..
That Australia online site you linked gives a blank when I try to load the datasheet for TSR-1 series.
Finally found one here at Tracor:
http://www.tracopower.com/fileadmin/medien/dokumente/pdf/datasheets/tsr1.pdf
which says minimum load is not required...
also says automatic current limit is at 2.5 amp ,
leading to another possibility, if you want to experiment:
IF your 1.4 amp load is only for brief tx intervals you might get away with using one regulator, briefly overloading it. Pay attention to keeping it in a cool location, and remember thin air doesn't cool as well as sea level (but temperature decreases with altitude).
old jim
  • · Replies 31 ·
  • · Replies 49 ·
  • · Replies 19 ·
  • · Replies 20 ·
