| Thread Closed |
Proof Using Def. of Groups and Def. of Subgroups |
Share Thread | Thread Tools |
| Oct9-03, 12:48 PM | #1 |
Hello,
This is my question: (i) Let H and K be subgroups of a group G. Prove that the intersection of H and K is also a subgroup of G. (ii) Give an example, using suitable sugroups of the goup of integers with the operation addition, (Z,+), to show that if H and K are subgroups of a group G, then the union of U and K need not be a subgroup of G. I figure that if I can do (i) then (ii) will follow. But I am unsure of how to do (i). (In previous assignments I did proofs on subsets, unions, intersections of sets but I did poorly on them.) I posted a previous question stating the four properties of a set of which all must be satisfied to be defined as group. From my understanding of subgroups, only two of these properties must be satisfied to define a subgroup of a group. Definition: A subgroup of a group G (G,o) is any nonempty subset H of G such that H is a group with the same operation, o. To check that H is a subgroup, verify the following: S1: If x and y are elements of H, then x o y is an element of H. s2: If x is an element of H, the the inverse is an element of H. If H and K are subgroups then they must satisfy the aforementioned properties. And as a consequence if S1 and S2 are satisfied, and because H and K are elements of G, the remaining 2 properties that define a group are satisfied as well. I also know that by definition, H intersects K iff some of the elements of K are also elements of H. But I am unsure of where to go from here, much less construct a proof that proves that the intersection of H and K is also a subgroup of G. (After typing this I think that I have some idea so I might be back later to submit more ideas/work regarding this question). Any help to steer me in the right direction would be appreciated. Thankyou. |
| Oct9-03, 02:30 PM | #2 |
Your problem is Proposition 2.1.2 at the following website. The complete proof is there, so you may want to only read a line at a time for a clue.
http://www.maths.lancs.ac.uk/dept/co...ap2/node2.html |
| Oct9-03, 02:45 PM | #3 |
Thanks Tom. I might get back to you if I don't understand a step or few. Or for some clarification of some concept. That happens from time to time you know. [:D]
Thanks again. |
| Oct9-03, 04:21 PM | #4 |
Proof Using Def. of Groups and Def. of SubgroupsThen x and y are members of ____ and, since ____ is a subgroup, x+y is in ____. Since x and y are members of H intersect K, they also are members of ___ which is a subgroup. Therefore, x+y is a member of _____. Since x+y is in ___ and ___, it is in ___ intersect ___. Fill in the blanks![:)] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Proof Using Def. of Groups and Def. of Subgroups
| Subgroups of Quotient Groups | Linear & Abstract Algebra | 0 | ||
| Fintie Groups; Subgroups | Precalculus Mathematics Homework | 14 | ||
| groups/normal subgroups | Calculus & Beyond Homework | 18 | ||
| normal subgroups, isomorphisms, and cyclic groups | Calculus & Beyond Homework | 11 | ||
| [SOLVED] Proof Using Def. of Groups | Introductory Physics Homework | 4 | ||
