Cubic Function Help Homework Statement
  • Thread starter Thread starter JazzMasterKC
    Cubic Function
The discussion revolves around a cubic function represented by a table of values for h(x) at specific x-values. The original poster attempts to derive a cubic equation based on the provided data, but encounters discrepancies between the calculated values and the graphical representation of the function.
  • Participants discuss the process of deriving a cubic equation from a set of data points and question the accuracy of the values obtained. There are attempts to reconcile differences between calculated and observed values from the graph.
Some participants have offered insights into the inconsistencies in the data and the challenges of fitting a cubic polynomial to the given points. There is recognition of multiple interpretations of the data, and some guidance has been provided regarding the accuracy of readings from the graph.
Participants note that the data may not fit a third-order polynomial exactly, and there are concerns about the accuracy of values derived from graphical interpretation. The original poster expresses frustration with problems based on graphical data.
JazzMasterKC
A table is given:
x | -2 | -1 | 0 | 1 | 2 | 3
h(x) | 0 | 9 | y | 3 | 0 | 6
Well actually the h(x) line was based on a graph that we had to look at, it should be right. I discovered y = 8 (the graph increments by 3 on y-axis and 1 on x axis, so I couldn't tell what y was)
so d = 8, b = -2
This graph is a cubic function, so I'm using ax^3+bx^2+cx+d formula
I got c=-8 and a=2
The first question that I got was to fill the h(x) part of table (thats all the direction I had)
Then the second part of the question was to figure h(3)-h(1).. ok yeah no problem easy enough..
However here is the catch.. using the found equation from my data.. well first this is what it is:
y=2x^3-2x^2-8x+8
.. so anyways I graphed in calculator and when I look at the table I noticed for x=-1 y=12.. which from viewing the graph its obvious that is false, The highest point on y-axis appears to be 10 at most from looking at graph... This has thrown me off and I'm not sure what to do now.. its clear I screwed up some where.
my results for equation (wrong) y=2x^3-2x^2-8x+8
cubic form: ax^3+bx^2+cx+d
Here are the four equations I derived out of the data to get what I thought was my answer..
-8a+4b-2c+d=0
-a+b-c+0=9
a+b+c+d=3
8a+4b+2c+d=0
I wish to evaluate h(3)-h(1) but I've noticed some errors with what I did in part 1 of the question.
JazzMasterKC said:
-a+b-c+0=9
Check that one again.
JazzMasterKC said:
A table is given:
so d = 8, b = -2
I got c=-8 and a=2
y=2x^3-2x^2-8x+8
-8a+4b-2c+d=0
-a+b-c+0=9
a+b+c+d=3
8a+4b+2c+d=0
There is a bit of inconsistency in your data. You get three slightly different cubic fits if you use x=(-2,-1,1,2) vs. x = (-2,-1,2,3) vs. x = (-2,1,2,3). These will give three slightly different values for h(0); I get h(0) = 8, 7.8 and 8.4, respectively.
Your data do not fit exactly to a third order polynomial. If the data were read from a graph, try to read more accurately.
ehild
thanks, though I can't stand these problems that are based from looking at a graph -_-
I ended up finding that 1x^3+2x^2-4x+8 (I think, just pullin from memory) fit exactly how it should with the exception x=3 y=5 looking a little sketchy from the graph, it looks like y=6 there to me... oh well this should suffice.
1x^3-2x^2-4x+8
Yep that's what I had sorry.
  • · Replies 19 ·
