Determine Motion of Two Planes in Deep Space
  • Context: Graduate
  • Thread starter Thread starter rajeshmarndi
    Motion Plane
The discussion revolves around the concept of motion as perceived by two planes in deep space, where no external reference points are available. Participants explore the implications of relativity in determining whether each plane can ascertain its own motion relative to the other plane.
  • Some participants propose that if each plane sees the other in motion, at least one must be in motion, but both could also be moving.
  • Others argue that without external references, each plane must consider itself at rest in its own reference frame, making it impossible to determine its own motion.
  • A participant emphasizes that motion is relative and cannot be assessed without specifying a reference frame, thus questioning the meaningfulness of determining one's own motion in isolation.
  • Another participant introduces the idea that if a plane accelerates, it can feel the acceleration, suggesting that self-awareness of motion can exist even without external references.
  • One participant suggests that in a thought experiment, one could use oneself as a basis for an inertial reference frame when starting from rest and then consider motion after acceleration.
  • There is mention of using Lorentz Transformation to create a new frame of reference, indicating a complex understanding of motion in different inertial frames.
Participants express differing views on the ability to determine one's own motion without external references. There is no consensus on whether self-awareness of motion is possible in the absence of external references, leading to an unresolved discussion.
Limitations include the dependence on the definitions of motion and reference frames, as well as the assumptions made about the conditions of the planes and their states of motion.
rajeshmarndi
Suppose in deep space there are only two plane and no other reference is available. And each plane see other plane in motion.
It is obvious that atleast one plane is in motion. But it is also possible that both plane are also in motion.
Can the observer in these plane, tell whether their own plane too, is also in motion.
Because to calculate other plane speed, an observer should know first whether his own plane is stationary or not.
Thanks.
OK, keep this all-important stipulation in mind when understanding the rest of your thread.
OK, now you have a second stipulation.
Yes, based on your two stipulations, you said that each plane can be a reference so in the rest frame of each plane, the other plane is in motion.
Not according to your first stipulation, you said that no other reference is available other than the two planes.
No, not according to your two stipulations, you said each plane sees the other one in motion and there are no other references so each plane must see itself at rest in its own reference.
No, because in Special Relativity, when we calculate the speed of any object, it is always according to a reference frame. And you stipulated that your two planes were the only references available. They are quite adequate, no other reference is necessary.
rajeshmarndi said:
Thanks.
You're welcome.
You seem to be ignoring the basic concept of relativity: an object is in "motion" only relative to something else. It makes no sense to ask if something is in motion without specifying what object (or reference frame) relative to which it is in motion.
That is why asking "Can the observer in these plane, tell whether their own plane too, is also in motion" is meaningless- you have not said "in motion relative to" a specific reference.
Here, since there are only two objects, there are only two reference frames- and so two answers. Each passenger on a plane sees his own plane as stationary relative to itself and in motion relative to the other plane.
Thanks.
If there is no other reference available or say no other reference is visible to a plane. And it accelerate, can we consider ourselves moving i.e we can always feel the acceleration.
That is to say, I might be in motion with some unseen reference, but I am not aware of it. Or say when I am lost in deep space.
In a thought problem, if you started out inertial, you could use yourself as the basis for an Inertial Reference Frame (IRF) in which you are at rest. Then you could accelerate and now you would be moving in the same IRF. So if I understand your question, the answer is yes.
You could start with the same IRF as defined earlier and then without accelerating at all, just use the Lorentz Transformation process to create a new frame moving at some speed with respect to the original IRF and now you have the object moving at some speed in a particlar IRF>
  • · Replies 37 ·
  • · Replies 84 ·
  • · Replies 34 ·
  • · Replies 24 ·
  • · Replies 96 ·
  • · Replies 26 ·
