Symmetrically Opposite Solution to Special Relativity
The discussion revolves around the concept of a "symmetrically opposite solution" to special relativity, particularly one where time is proposed to go backwards. Participants explore the implications of this idea on the behavior of rulers and clocks, as well as the mathematical frameworks involved, including Lorentz transformations and the Lorentz group.
  • Some participants mention a "symmetrically opposite solution" to special relativity where time goes backwards, but the source of this idea is unclear.
  • One participant suggests that the "time reversal" operator may relate to the discussion, noting that it satisfies the definition of a Lorentz transformation.
  • Another participant introduces the concept of the full Lorentz group, O(1,3), as potentially relevant to the discussion.
  • There is a proposal that special relativity can be viewed as an orthogonal projection with a slight rotation, with the opposite solution involving a rotation in the opposite direction.
  • A mathematical representation of Lorentz transformations in 1+1 dimensions is provided, highlighting how a transformation with a negative sign for the time component could reverse the direction of time.
  • Some participants express uncertainty about how time dilation and length contraction would be affected under non-orthochronous Lorentz transformations.
  • There is mention of tachyons in relation to the discussion, suggesting a connection to the proposed opposite solution.
  • One participant reflects on the "loaf of bread model of time," describing how different frames of reference might perceive time slices differently, leading to confusion about the nature of these slices in relation to the proposed opposite solution.
Participants do not reach a consensus on the validity or details of the "symmetrically opposite solution." Multiple competing views and interpretations remain, with some participants questioning the original premise and others attempting to clarify or expand upon it.
Limitations include the lack of a clear reference for the original idea, varying levels of understanding of the mathematical concepts involved, and the speculative nature of the proposed opposite solution.
wmikewells
I read some place that there is an symmetrically opposite solution to special relativity where time goes backwards, but darn if I remember where I read it. The opposite solution is largely ignored because it does not have any real world application.
I know that traditional special relativity has three effects on a reference frame moving relative to me:
1. rulers are contracted
2. clocks go slower
3. leading clocks are adjusted back in time and trailing clocks are adjusted ahead in time
I was just curious what effect the opposite solution to special relativity had on rulers and clocks. I played with the rulers and clocks for a bit, but I couldn't come up with the solution.
I don't know what "opposite" you have come across. It doesn't sound like anything I've heard of, so my first guess would be that you just misunderstood something at the time you read it. I suppose you could be talking about the fact that the "time reversal" operator
\begin{pmatrix} -1 & 0 & 0 & 0\\ 0 & 1 & 0 & 0\\ 0 & 0 & 1 & 0\\ 0 & 0 & 0 & 1\end{pmatrix} satisfies the definition of "Lorentz transformation".
You really need to have a reference when you ask for an explanation of something you've read, especially when it's something that's this hard to identify.
I am not certain, but it sounds like you may be talking about the full Lorentz group, O(1,3). The part that usually pertains to special relativity is just the restricted Lorentz group SO+(1,3). Here is a brief overview:
http://en.wikipedia.org/wiki/Lorentz_group#Connected_components
Thank you for your replies. I give my apologies for not being able to produce the source of the idea. I'll take a look at the restricted Lorentz group link to see if that is what I was referring to.
Unfortunately, I was surfing the Internet while looking into another issue, and I read the paragraph or two about the opposite solution. I thought it was cool, but I was after other fish, so I filed it away in my memory and went on. I am not so sophisticated as to understand what the "time reversal operator" is, but the gist of the idea I happened upon is this (if my memory serves me correctly).
Special relativity is like an orthogonal projection with a slight rotation. It is a common tool in explaining special relativity although I can't seem to find any diagrams in Wikipedia as I am writing this. The rotation accounts for the length contraction and time lengthening. I have seen this explanation in several popularized versions of special relativity. Standard special relativity rotates in one direction. However, the symmetrical opposite solution rotates in the opposite direction. The opposite rotation presents a solution where time goes backward, so it has no real world application. I wish I was more expert in relativity to explain in detail what I was talking about.
I'll try to fill in the missing pieces as I wait for a reply.
I took a look at the link above (http://en.wikipedia.org/wiki/Lorentz...ted_components ), and unfortunately, it is above my pay grade. I'll try to find an example of the orthogonal rotation example I mentioned, and maybe I'll get lucky and find an explanation about the opposite solution.
In 1+1 dimensions, a Lorentz transformation is a matrix
$$\frac{\sigma}{\sqrt{1-v^2}}\begin{pmatrix}1 & -v\\ -\rho v & \rho\end{pmatrix}$$ where ##v## is the velocity, and ##\sigma,\rho\in\{-1,1\}##. A restricted Lorentz transformation is one with ##\sigma=\rho=1##.
A Lorentz transformation with ##\sigma=-1## changes the sign of the time component when it acts on a coordinate pair of an event on the time axis. In this sense, it "reverses the direction of time".
I think he/she may be asking how time dilation and length contraction are affected/reversed, if at all, under the elements in the connected component of ##O(3,1)## which corresponds to non-orthochronous Lorentz transformations.
EDIT: I should add that what you normally think of as time dilation and length contraction are simply special cases of Lorentz boosts applied to the coordinate representations of position vectors. Any Lorentz boost can be decomposed into consecutive infinitesimal transformations belonging to the connected component of ##O(3,1)## which contains the identity transformation (the decomposition will start with the identity transformation). The time reversal Lorentz transformation (which is non-orthochronous by definition) belongs to a connected component which does not contain the identity so I am still unsure about what you are even trying to describe physically.
It's not. A restricted Lorentz transformation is however a hyperbolic rotation. This can be seen by defining an angle ##\theta## by ##\tanh\theta=v##, and rewriting the Lorentz transformation in terms of that angle (the "rapidity") instead of the velocity.
It could be that what you have seen is that when we look for transformations between inertial coordinate systems that are consistent with the principle of relativity and rotational invariance of space, we find reflections, Galilean boosts, restricted Lorentz transformations (i.e. hyperbolic rotations of spacetime), and plain old rotations (of spacetime). The rotations can be ruled out by other things. One of the problems would be that we would be able to rotate the "time axis" all the way down to what was previously the "space axis", so that what one inertial observer thinks of as velocity 0 is infinite speed to another. These arguments are far more difficult to understand than special relativity. They are also more difficult than the stuff about connected components of the Lorentz group.
FWIW, I think the OP is talking about Lorentz transformations applied to tachyons.
That's possible too. I didn't think of that for some reason.
wmikewells, you should see by now that this is impossible. We can't keep guessing what you might have heard at some point, when all you remember is that it involves time going backwards, and maybe rotations.
I will try to find the original reference. I thought it might be an obscure, but common piece of knowledge for those in the know, something along the lines of the Terrell–Penrose effect, which I just recently learned about (not that the two are related). Thanks for trying to make sense of my confusion.
I figured out one half of my mystery. I did a little more digging. The model I was looking for is the loaf of bread model of time. If my frame and another frame (let's say the star Vega) are not moving with respect to each other, our "slice" of time will be perpendicular slice. However, if the other frame is a rotating planet around Vega, the "slice" of time for the Vega planet will be a French cut (diagonal). The French cut will reach into my past if the Vega planet is receding from me, and it will reach into my future if the Vega planet is approaching me. I mistakenly believed that only one French cut was possible and that special relativity presented that one French cut. When I read about a symmetrically opposite Lorentz contraction solution, I wrongly assumed that it represented the other French cut. However, special relativity accounts for both French cuts: one into my past and one into my future. So, one half of my mystery is resolved, but the other half of my mystery is still open. The thing that has thrown me for a loop is that the source for the symmetrical opposite solution was not some cracked pot on physics forum like myself. Maybe one of the books I have read recently. I'll dig a little more and open another thread if I find it.
  • · Replies 32 ·
  • · Replies 29 ·
  • · Replies 54 ·
  • · Replies 16 ·
