Joule-Thomson Effect: Understanding the Physical Explanation
  • Thread starter Thread starter sliorbra
The Joule-Thomson effect describes the temperature change of a gas when it expands adiabatically, with the internal energy change equating to the net work done on the gas. During expansion, the gas's potential energy increases, leading to a decrease in temperature from T1 to T2, as its kinetic energy is converted to potential energy. The Joule-Thomson coefficient (μJT) can vary significantly, with values ranging from +3 to -0.1 K/atm, depending on the gas and pressure conditions. Understanding this effect is crucial for applications such as the production of liquid nitrogen through Joule-Thomson expansion.
  • Understanding of thermodynamics, particularly adiabatic processes
  • Familiarity with the concept of internal energy in gases
  • Knowledge of the Joule-Thomson coefficient (μJT) and its implications
  • Basic principles of gas expansion and potential energy
  • Study the derivation and implications of the Joule-Thomson coefficient (μJT)
  • Explore the principles of isoenthalpic processes in thermodynamics
  • Learn about the practical applications of Joule-Thomson expansion in cryogenics
  • Investigate the differences in Joule-Thomson behavior among various gases
This discussion is beneficial for students and professionals in thermodynamics, chemical engineering, and cryogenics, particularly those involved in gas behavior analysis and refrigeration technologies.
sliorbra
Hello,
I have a problem to understand properly this effect. I understand that during the process the change in the internal energy of the gas is equal to the net work that have been done on it.
So far everything is fine. My problem is with the physical explanation of the phenomenon.
Lets assume for now that the attraction forces are the dominant one.
According to the explanation I always hear,when the gas expands, its potential energy increases, and because it doesn't have any other energy source [since the process assumed to be adiabatic], the source to the increase in the potential energy is his kinetic energy. Therefore, the temperature of the gas decreases from T1[the temperature in the initial region] to T2[the temperature in the final region].
BUT, in the first step of the process work is done on the gas, what increases his internal energy, and just then occurs expansion. So the situation where the gas uses his own energy to expand occurs just after some work was done on him.
So, why does the temperature of the gas can't be increased in the first step by the the work that is done on it, and then reduce due to the expansion, in such manner that the total temperature change is positive?
I feel that all the explanations I've read so far ignore the first step of the process...
Chemistry news on Phys.org
The Joule-Thomson coefficient ((dT/dP)H) can indeed have positive or negative values, depending on the gas or the pressures used in the two chambers. From Levine, 6th Edition, values of μJT can have values of +3 to -0.1 K/atm.
From the same book, the point of a JT expansion is to do it with the same gas at different pressures and build an isoenthalpic curve which can then be used to determine the sign and magnitude of μJT. Then you can use your information to figure out how to do real things, such as making liquid nitrogen, which is, I believe, done via a JT expansion.
  • · Replies 67 ·
  • · Replies 22 ·
  • · Replies 33 ·
