Which battery would be suitable for UPS in hot area?
  • Thread starter Thread starter signode
    Area Battery Hot
The discussion centers on selecting a suitable 12V-70AH battery for a UPS in high-temperature environments, specifically up to 42°C. Flooded lead-acid batteries are unsuitable due to their reduced lifespan at elevated temperatures, losing half their life for every 8°C increase. Lithium-ion and nickel-cadmium batteries are viable alternatives, with lithium-ion operating between -20ºC to +60ºC and nickel-cadmium excelling in extreme conditions from -40ºC to +60ºC. The Durathon Sodium-nickel-chloride battery is highlighted as the optimal choice, functioning effectively from -40°C to 65°C without requiring temperature control.
  • Understanding of UPS (Un-interruptible Power Supply) systems
  • Knowledge of battery chemistries, specifically lithium-ion and nickel-cadmium
  • Familiarity with temperature effects on battery performance
  • Awareness of Durathon Sodium-nickel-chloride battery technology
  • Research the specifications and applications of Durathon Sodium-nickel-chloride batteries
  • Explore the advantages of lithium-ion batteries in UPS systems
  • Investigate nickel-cadmium battery performance in extreme temperatures
  • Learn about environmental control options for battery systems in high-temperature settings
Electrical engineers, UPS system designers, battery technology specialists, and anyone involved in selecting batteries for high-temperature applications.
signode
Hi;
I want to select a battery 12V-70AH for a UPS (Un-interruptible Power Supply) but problem is “temperature”. The environment temperature where UPS would be installed can be raised up to 42C. So the flooded lead acid batteries can not work there as each 8C of temperature rise decreases the life of lead acid battery by half. Can anyone suggest me then which battery should be selected?
http://www.saftbatteries.com/battery-search/sble-sbm-sbh-block-battery
http://www.falconups.com/ups/SSGRP_1k-3k_ultrawide.pdf
“Lithium-ion cells are rechargeable and deliver a voltage of 3.7V, have no memory effect, operating temperature range from -20ºC to +60ºC. Nickel-cadmium batteries have a legendary reputation for robustness, reliability and service life. This is the benchmark technology for difficult and demanding applications: operating temperatures from –40ºC to +60ºC, excellent cycling capability, long storage life, and low or zero maintenance.”
http://www.bipowerusa.com/documents/bat.tech.asp
Here’s an excellent overview of probably the best choice:
http://www.wikifacetube.com/Sodium-Nickel-Chloride_battery
“Durathon Sodium-nickel-chloride battery technology is suitable to operate in extreme ambient temperatures without adversely affecting energy delivery, life cycle and safety.
Durathon Batteries do not require the use of air conditioning or heating and are capable of operating at temperatures ranging from -40°C to 65°C.
The Durathon Battery’s chemistry does not develop significant vapor pressure until the cell temperature reaches a level 450°C (842°F) above the nominal battery operating temperature. This gives the Durathon Battery significant thermal margin to avoid high pressures within the cells.”
Manufactured by:
General Electric Energy Storage
1 River Road, Bldg. 66
Schenectady, N.Y. 12345
http://geenergystorage.com/backup
http://geenergystorage.com/backup/brochures
signode said:
Hi;
Just curious. Are you using a these (lead-acid?) batteries in a series arraignment to get, say, a 120vdc or 240vcd source? The trade-off of battery cost vs. cost of environmental control may need to be considered.
Regards
  • · Replies 26 ·
11K
  • · Replies 17 ·
  • · Replies 21 ·
9K
  • · Replies 16 ·
