What are upper and lower bounds and why are they important in mathematics?
  • Context: Undergrad
  • Thread starter Thread starter woundedtiger4
    Bound Upper bound
The discussion revolves around the concepts of upper and lower bounds in mathematics, specifically focusing on their definitions, properties, and implications in various contexts. Participants explore theoretical aspects, clarify definitions, and engage in conceptual reasoning regarding supremum and infimum.
  • Some participants question why certain numbers are considered lower bounds for specific sets, noting that a lower bound does not need to be an element of the set.
  • There is a discussion about the supremum, with some participants asserting that while 4 is an upper bound for the set {1, 2, 3}, it is not the least upper bound, which is 3.
  • One participant states that any rational number greater than √2 is an upper bound for the set of rational numbers intersecting the interval from -√2 to √2.
  • Another participant clarifies that the greatest lower bound is defined even if a set does not have a minimum, emphasizing that this is true in the real numbers.
  • There is a distinction made between maximum/minimum and supremum/infimum, with some participants discussing the conditions under which these terms apply.
Participants express differing views on the definitions and implications of upper and lower bounds, particularly regarding the existence of least upper bounds and the relationship between bounds and set membership. The discussion remains unresolved with multiple competing views present.
Some statements rely on specific definitions and assumptions about sets and their elements, which may not be universally agreed upon. The discussion also touches on the properties of rational and irrational numbers in relation to bounds.
woundedtiger4
At:
http://en.wikipedia.org/wiki/Upper_and_lower_bounds
in example it says that
"2 and 5 are both lower bounds for the set { 5, 10, 34, 13934 }, but 8 is not"
Why "2"? as 2 is not in that set.
Also,
at:
http://en.wikipedia.org/wiki/Supremum
"The "Supremum" or "Least Upper Bound" of the set of numbers 1, 2, 3 is 3. Although 4 is also an upper bound, it is not the "least upper bound" and hence not the "Supremum"."
Why? as 4 is not in the set of 1,2,3 but if for a moment I think that as 4>3 so it is the upper bound of the set which contains 1,2,3 then am I correct to say that 3 is the least upper bound ?
Thanks in advance.
A lower bound of a set A is any number x such that x<a for any ##a\in A##.
So we don't need the number to be in the set (if the element is in the set, then it's called a minimum). A lower bound is just any number smaller than each element in the set.
So 5 is the greatest lower bound.
Yes. Anything lower than 5 is also a lower bound.
(Copy/pasted from wiki)
Question: as Q doesn't have the least upper bound as 2^1/2 is irrational but the example says that Q has an upper bound, is that upper bound any number greater than 2^1/2 or is it a specific number?
Thank you so much.
Any rational number greater than ##\sqrt{2}## is an upper bound.
Once again, thank you very much sir.
In fact, because 5 is in the set, 5 is the minimum of the set.
(If a set has a minimum (smallest member) then that minimum is the greatest lower bound.) But as long as a set has lower bounds, it has a greatest lower bound whether is has a minimum or not.
Of course, that is only true in ##\mathbb{R}##.
No, it does not say that Q has an upper bound! It says that Q intersect the interval from [tex]-\sqrt{2}[/tex] to [tex]\sqrt{2}[/tex] has upper bounds. 1.5, for example is an upper bound of that set.
(But Q, the set of all rational numbers, does NOT have either upper or lower bounds.)
What does upper bound, least upper bound (supremum), lower bound, and greatest lower bound (infimum) tells us intutively? It just tells us lower & greater numbers, right?
Is maximum (max) is just an other word for least upper bound (supremum), and similarly minimum (min) is just an other word for greatest lower bound (infimum)?
Yes, the upper and lower bound just tells us lower and greater numbers. The greatest lower bound also tells us a lower number, but the best possible one.
Not exactly. A minimum of a set A is an infimum that also belongs to the set.
For example, 1 is an infimum of (1,2], but not a minimum since 1 does not belong to the set. On the other hand, 1 is a minimum of [1,2] and thus also an infimum.
  • · Replies 17 ·
