Transitional state of electrons.
  • Thread starter Thread starter airkapp
    Electrons State
The discussion focuses on calculating the width of a rigid box containing an electron transitioning from n=3 to n=1, resulting in the emission of a 240 nm photon. The energy of the photon is calculated using the formula E = hc/λ, yielding an energy of 1.33E-19 J. The width of the box is derived from the equation L = √(h² / (8mE)), resulting in an approximate width of 1.08E-10 m, or 108 picometers. The calculation assumes a one-dimensional box, and variations in dimensionality would alter the results.
  • Quantum mechanics fundamentals
  • Understanding of photon energy calculations
  • Familiarity with the concept of a rigid box in quantum physics
  • Basic knowledge of the Planck constant and electron mass
  • Research the implications of dimensionality on quantum box calculations
  • Explore the concept of electron momentum in quantum mechanics
  • Learn about energy transitions in quantum systems
  • Study the relationship between wavelength and energy in photons
Students and professionals in physics, particularly those studying quantum mechanics, as well as educators looking to explain electron transitions and energy calculations in rigid boxes.
airkapp
This is how I went about it but I am unsure if it is correct..
An n=3 to n=1 transition from an electron trapped in a rigid box produces a 240 nm photon. What is the width of the box?
λ = hc / E:
E = hc / λ
E = (1.06E-34 J*s * 3E8m/s) / 240nm
= 1.33E-19 J
E = h2 / 8mL2
L2 = h2 / 8mE
L = √ h2 / 8mE
L = √ ((1.06E-34 J*s) 2 / (8*9.11E-31kg*1.33E-19 J))
= 1.08E-10 m
You are missing a factor of 8:
Allowed values of electron momentum are:
[tex]p = \frac{hn}{2L}[/tex]
Since [itex]E = p^2/2m[/itex], the allowed energy values are:
[tex]E = \frac{n^2h^2}{4L^2}\frac{1}{2m} =n^2\frac{h^2}{8mL^2}[/tex]
The change in energy between n=3 and n=1 results in the photon (E=hv):
[tex]\Delta E = (9-1)\frac{h^2}{8mL^2} = \frac{hc}{\lambda}[/tex]
[tex]L^2 = 8\frac{h\lambda}{8cm}[/tex]
[tex]L = \sqrt{\frac{h\lambda}{cm}}[/tex]
AM
Therefore, the width of the box is approximately 108 picometers. This calculation assumes a one-dimensional box, as the question does not specify the dimensions of the box. If the box is two or three-dimensional, the calculation would change accordingly.
11K
25K
