How would gravity act on an object with no velocity?
In a gravitational field, an object with no initial velocity will move directly toward the center of the planet, not follow a circular pathway. This is due to the gravitational force acting as a net force directed toward the planet's center. The object's motion is analogous to that of a dropped rock, which accelerates straight downwards. If the planet is rotating, the impact point will differ from the initial position due to the planet's rotation, but this does not affect the object's trajectory.
  • Understanding of gravitational force and its directionality
  • Knowledge of Newton's laws of motion
  • Familiarity with concepts of circular motion and centripetal force
  • Basic principles of planetary rotation effects on falling objects
  • Study Newton's law of universal gravitation
  • Learn about the effects of rotation on falling objects in a gravitational field
  • Explore the principles of circular motion and tangential velocity
  • Investigate the implications of gravitational acceleration on different celestial bodies
Physics students, educators, and anyone interested in understanding gravitational dynamics and motion in a planetary context.
safwan.hossain
Suppose there was a planet in deep space. Now drop an object in it's gravitational field. This object has no velocity whatsoever in any direction. Now, would this object start moving straight toward the planet (because that's the direction of net force) or follow a circular pathway (because gravity is a centripetal force). Please explain why?
My intuition tells me that this object would follow a circular pathway. But I have no way to rationalizing why.
You need to revisit you circular motion physics - can you have a curved path without any initial tangential velocity?
I have no idea why your "intuition" would say such a thing! The gravitational force on an object acts directly toward the center of the planet. The same thing will happen to this object that would happen to a rock when you dropped it- it will move straight "down" toward the surface.
If the planet is rotating, the point at which the object hits the surface will not be the point that was directly beneath the object when it started falling but that is due to the rotation of the planet, not the motion of the object.
  • · Replies 16 ·
  • · Replies 39 ·
  • · Replies 30 ·
  • · Replies 31 ·
