Clarification on what the questions asking
  • Thread starter Thread starter Jacob87411
The discussion clarifies the interpretation of a physics problem involving light interference in a thin oil film on a glass plate. The problem states that destructive interference occurs at a wavelength of 500 nm and constructive interference at 750 nm. The key takeaway is that the question specifically refers to these wavelengths, indicating that at 500 nm, the reflected light interferes destructively, while at 750 nm, it interferes constructively. The thickness of the oil film can be calculated using these interference conditions.
  • Understanding of thin film interference principles
  • Familiarity with the refractive indices of materials (e.g., n=1.61 for glass, n=1.2 for oil)
  • Knowledge of wavelength and its relation to light behavior
  • Basic skills in solving equations related to optical path differences
  • Calculate the thickness of the oil film using the interference conditions at 500 nm and 750 nm
  • Explore the formula for thin film interference, specifically for constructive and destructive interference
  • Research the impact of varying refractive indices on light interference patterns
  • Study practical applications of thin film interference in optical devices
Students and professionals in physics, particularly those studying optics, as well as educators looking to explain thin film interference concepts effectively.
Jacob87411
A glass plate (n=1.61) is covered with a thin uniform layer of oil (n=1.2). A light beam in air of variable wavelength is normally incident on the oil surface. Observation of the reflected beam shows destructive interference at 500 nm and constructive interference at 750 nm. Calculate the thickness of the oil film from this information.
Is the question saying that when the wavelength is 500 its destructive and when wavelength equals 750 its constructive or after 500 nm it interferes destructively and at 750 nm it interferes constructively
I would interpret the question the way you did the first time around i.e. since the question says the incident beam's wavelength can vary (this is the key bit of info), I would intepret it to mean the following:
1. When the incident beam has a wavelength of 500 nm, the reflected beam interferes destructively with it.
2. When the incident beam has a wavelength of 750 nm, the reflected beam interferes constructively with it.
To be honest, I find the wording of your second interpretation to be even more confusing than the original question :-p , and I am really not sure what you are driving at because I can't understand what is meant by "after 500 nm" and "after 750 nm."
I'm pretty confident what I wrote above (1 and 2) is the right interpretation.
?The question is asking for the thickness of the oil film on the glass plate based on the observed destructive and constructive interference at specific wavelengths of light. This means that at 500 nm, the reflected light shows destructive interference, while at 750 nm, it shows constructive interference. The question is not specifying whether the interference occurs immediately after 500 nm or 750 nm, but rather at those specific wavelengths.
9K
